Question about Bosch WFMC 3200 Front Load Washer
Clothes just don't seem to smell clean
I have been using the Bosch 500 series washer and it seems that the clothes just don't smell clean especially towels. I have tried different detergent. Is this s common problem? Perhaps the water effeciency reduces cleanleness???
  • stebenn1 Mar 20, 2008
    We have the same problem with the 3200, I run a cycle through with bleach and no clothes and it seems to help some.
We have the same problem with the 3200, I have run a cycle through with no clothes and adding bleach instead of detergent.
Seems to help some.
Posted on Mar 20, 2008
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
We have just moved into a house and the indesit washer dryer makes the clothes smell off. Have cleaned out the drawer, cleaned out the seal around the door, put it on a hot wash with soda crystals, used a...
i knew someone that had that problem, and they said they ran vinegar through the washer. I dont know how true it was, but they said they never had the problem again.
Apr 29, 2012 | General Washing Machines
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Error code 13 on my 5oo plus series washer, it will not coplete the load or unlock the door, im afraid the clothes are going to start smelling
On the small round disk at the bottom right...insert a small round pointed object into the hole and push gently, while do this rotate the disk clockwise. This will allow you to remove the disk. Look inside and there will be a slender plastic rod next to the drain clean out. Pull down gently to manually unlock the washer door. Unfortunately that will unlock the door but probably not fix what caused the issue in the first place.
Jan 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Is there any detergent I should avoid using in my Bosch Nexxt 500 Series washer?
Any clothes-washer HE (low suds) soap will do. Just be aware that you only need a tablespoon of the soap, not the 3/4 cup that comes in the box!
Oct 17, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Stinky towels
Mildew odor in towels in almost invariably being transferred from the washing machine. The clothes washer must be cleaned first then clean the smelly towels and laundry. To compare washer cleaners watch this video of Affresh and Smelly Washer...
http://www.youtube.com/watch?v=Ua6OJPn0-fU
Apr 19, 2008 | Washing Machines
Bosch WFMC 3200 Front Load Washer Logo
182 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
