Question about Dell E173FP 17" LCD Flat Panel Monitor
Dell AS501 flat screen monitor
Instead of going to power saver mode my monitor cycles through a series of full screen colors at 3 second intervals (Red, Green, Yellow, Turquoise, White, Blue). if I move the mouse it returns me to the log in screen, 35 minutes later it will begin the full color rotation again. I attempted to turn off the monitor and could not do so. I had to unplug it, let it sit 15 minutes, plug it in, (it was still on) and then turn it off. This is the third time I could not turn it off in 3 days each time I had to unplug it, plug it back in, then turn it off. Any ideas about what is wrong? The monitor is about 2 1/2 years old came with a dminesion 5150 computer.
  • Anonymous Mar 25, 2008
    I have exactly the same problem. I have tried unpluging it and tried to change the screen saver without any luck.
    Champion:
  • 220 Answers
The front panel switches seem to be the culprit.
If you are technically sound you maybe able to solve problem by opening monitor and clean front panel switches or replace them.
Samir.
Posted on Mar 20, 2008
How can I disable my monitor's sleep mode? I don't want the screen to go black, I want to be able to see the screen saver as it cycles. Thank you.
You can do this in the Power Savings options with Windows. For Windows 7, rght click on the display (anywhere with no icons or running programs) and choose Personalize. Click on Screen Saver in the lower right hand corner. Adjust the Wait time for the screen saver if desired and click Apply. Then click on Change Power Settings. This brings up the Control Panel > Hardware and Sound > Power Settings. Then click on Edit Power Settings for the active power plan. (For desktops it is usually the balanced power). Then change the setting for Turn off monitor to Never when plugged in. Also change the Sleep time for the computer to Never. You can do the same for when on battery but it will shorten the length of time that the computer will be able to run on the battery for laptops. Then Save Changes and close the windows.
For older versions of Windows, these advanced power settings are also available from the Screen Saver settings page but details may differ.
I hope this helps.
(for most monitors, as long as the computer is sending a signal the monitor will stay on)
Dec 23, 2010 | Dell 22" SP2208WFP Widescreen Flat Panel...
Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
Sep 21, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Screen comes on for a second then goes black. It
its just ur monitor setting or the setting in ur pc for stand by mode or power saver mode.
if u still could not figure it out pl say me which system u using(platform)
Jun 01, 2010 | Computers & Internet
My monitor keeps going into power save mode
Its not power saver mode, when the display goes black and the power light starts flashing that is a good indication that the power supply is about to die. The Dell E172 monitors are noted for this problem. We have step by step repair guides posted on our web site at: www.ccl-la.com Click on the monitor repair link. The Dell E172 series actually has several sub models, check your specific model, the sticker on the back will have either E172FPb, E172FPc, E172FPf. We have guides for all 3 versions posted.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 30, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
My Dell E176FPc monitor seems to be stuck in power saver mode. There is no way to access the on screen menu. When the monitor is unplugged from the compouter, it shows a self test screen with 3 colored...
Try the monitor if you can on another computer and see if it stays in power save mode. If it does then the monitor is bad.
If you try the monitor on another computer and you get video then that means theres an issue with the original computer.
Aug 04, 2009 | Dell E176FPC Monitor
AS501 Monitor Problem
Your monitor have a bad condensatorin the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive) or if you have electronic tools, found and replace that condensator.(cheaper way...)
Best Regards!
Jun 24, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
Dell Ultrasharp 1800FP Power Saving Mode
go to control panel>power option>power scheme.
adjust the hard drive to 30 mins and everthing else 20 minutes.
also, go to display and adjust the screen saver to be longer. up to 9999min.
Jun 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 17" flat screen monitor
When they stay in power save mode the logic board is usally the problem. Cneck out www.lcdrepair.us they sell all the parts for that unit.
Dec 10, 2007 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell E173FP 17" LCD Flat Panel Monitor Logo
409 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
