Question about JVC HD-52G786 52" Rear Projection HDTV
Bulb problem How do I check to see if the bulb is bad?
  • StevenDarryl Mar 03, 2008
    I really do appreciate the quick response and feedback. The only reason it wasn't helpful was that I had already been to that website and I was too dumb to figure it out.
  • 2,336 Answers
Check HERE for instructions on how to determine if the bulb is defective.
Posted on Feb 28, 2008
  • Jaime Hernandez Mar 03, 2008
    I'm sorry you feel that way about my response. The way this works is if you give more info about your problem, you will get a better answer.
Drivers side turn signal blinking fast other side normal, bulb change didn't help
Even after bulb change, do all lamps work? Bad ground can be shown by weak or dim bulb sometimes and this can cause fast flashing. All bulbs which flash must be working and of normal brightness which is sometimes hard to tell when they blink really fast.
Feb 27, 2015 | 2006 Lincoln Town Car
One brake light out , bulb is good
Replace the bulb, only partial is good. It is one bulb for low brake light and high break light when you press the brake pedal.
Apr 29, 2014 | 2000 Ford Focus
2002 dodge durango left turn signal works right turn signal does not
have you checked the bulbs front and back. to see if they work, bulb check. then it sounds like you might have a bad signal flasher that only works the left side and not the right side. or if a bulb at the front or the rear gets bright but not the opposite bulb on the same side then you may just have a bad bulb or socket or power to the socket when doing the bulb check.
Mar 06, 2014 | 2002 Dodge Durango
Lowbeam head light went out put new bulb in still not working checked fuses they looked good anyone have any sugestions
IF IT WORKS ON HIGHBEAM THEN BAD BULB DO NOT TOUCH BULB GLASS WHEN INSTALLING. CHECK PLUG INTO BACK OF BULB FOR CORROSION, CLEAN AND USE A LITTLE GREASE, TEST BEFORE REINSTALLING
Jan 08, 2014 | 2000 Chrysler Town & Country
Left headlight no working
It can only be one of a handful of problems. The most obvious is just a bad bulb. Another is that the socket that the bulb connects to is bad. You can also check and see if you have a fuse that is specific to the left headlight. You should check to see if the socket/bulb assembly is getting any electrical power. That will help out in a big way. If you are getting power to it, then its either the bulb or the socket that is bad. (Try the bulb, first.)
Mar 27, 2013 | 1999 Pontiac Grand Am GT
2000 mercury mountaineer one headlight works the other does not and its not the bulb
Not good!
Simple/ not so simple...
Need to put a multimeter on it and see if you're getting power at the bulb. If not, you'll need to replace the entire wire from where the two headlights join together to the bulb.
Only other possibility is that it really is the bulb, and you got a bad bulb to replace a bad bulb. Easiest check would be to pull the bulb from the other side (knowing it works), and put it in there to see if that fixes it (and also put the replacement bulb in the good side to ensure it's a good bulb, too).
Sep 02, 2012 | Mercury Mountaineer Cars & Trucks
No left blinker
bad buib try switching left to right if it works if it works your bulb is bad if not you might have a bad bulb socket or bad power wire !!!! either way a easy fix
Feb 16, 2011 | 1989 Chevrolet K1500
Drivers side brake light and horn won't work,,is it the multi function switch? 1999 chev blazer 4x4 . if so how much does a new one cost?
No there not connected, replace the brake light
1999 Chevrolet Blazer Auto Light Bulb Size Guide
Low Beam Headlight Bulb Size: 9006
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 3157
Front Turn Signal Light Bulb Size: 3157
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 880 or 881
License Plate Light Bulb Size: 194
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 161
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 168 or 211-2
Step/Courtesy Light Bulb Size: 168 or 211-2
Trunk/Cargo Area Light Bulb Size: 211-2
Under Hood Light Bulb Size: 93
Instrument-General Light Bulb Size: 161 or 37 or PC194 or PC74
Check Engine Indicator Light Bulb Size: PC74
Hi-Beam Indicator Light Bulb Size: PC74
Seat Belt Indicator Light Bulb Size: PC194
Brake Warning Light Bulb Size: PC74
Automatic Transmission Indicator Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: PC74
As for the horn, inspect the fuse and relay and most common it would be a bad ground wire or worst a bad horn due to corrosion. Horn will be located in the drivers side fender.
Thank you for using fixya.
May 13, 2010 | 1999 Chevrolet Blazer
Bulb failures with no real pattern
check the front and rear turn signal and brake bulbs ,check for filament wear or drakness in bulb glass.if this is found replace bulb,you may also have a bad ground to a bulb socket, turn lights on (signal and break) and wiggle wires at bulb socket, watch light, if it dim any replace that socket and check the ground wire.
Mar 04, 2010 | 1989 Jaguar Vanden Plas
Scanner not working - get error message
First, check to see if the bulb lights up, if not you have bad bulb. the bulb can be ordered separately. if the bulb is good, you have a problem with the main board.
Nov 02, 2007 | Epson Perfection 1240U Flatbed Scanner
JVC HD-52G786 52" Rear Projection HDTV Logo
59 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
