Question about Sub-Zero 632 / S
Sub-zero 632 error code 24
I emptied the ice bucket to get "fresh" ice. A couple of days later I noticed the ice bucket was half full of water that had frozen into one large block of ice. Then I noticed I now have EC 24 with "service" flashing. I turned the ice off and am now wondering what to do next. I am just into the 6th year since installation so only parts are covered by my warranty.
Any suggestions?
  • 2 more comments
  • Anonymous Apr 17, 2008
    I am struggling with same problem (EC 24) . Tech coming out today. Will advise
  • Anonymous Apr 24, 2008
    Same problem. Half Ice, half frozen block in bottom of bin
  • Anonymous May 23, 2009
    Followed your advice and the error message went away. Forgive my novice question. What is the Auger Bucket : Is this the same as the Ice Bucket Bin. Your advice much appreciated.
    Clueless Homeowner
  • Anonymous Mar 31, 2014
    can see block of ice on ice maker when ice bucket removed not making ice cubes for 2 days
Clean out auger bucket ec-24 is defrost underheat,to clear press and hold bell on/off key for 15 seconds.
ALL APPLIANCE REPAIR L.L.C
HOT SPRINGS
Posted on Jul 16, 2008
What is sub zero refrigerator error code 24
if there are no additional errors present check the defrost circuit, (wiring,heater, thermistor, defrost thermostat). work should be done by a qualified technician.
Aug 19, 2014 | Sub-Zero 632 / S
Sub zero leaks water
You need to replace that water line, except it's not on top on a 632. And those weren't available in 1994. Do you maybe have a 590?
Jun 26, 2014 | Sub-Zero 632 / S
My sub zero ice smells bad like fish how di I remove and clean?
My ice maker smells like bad fish too! Emptied everything out. Cleaned every part, placed baking soda inside to absorb odors, but still stinks! Why? What more can I do?
Mar 07, 2011 | Sub-Zero 632 / S
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
EC 24
It is absolutely the ice bucket. Just a different name. If you are may be getting teh error then there may be ice build up causing an obstruction on th full sensor or the bucket tracks. Make sure the area is clear of obstruction and unplug the unit for ten minutes. If everything is clear the error code should go away. Make sure you leave it unplugged for ten minutes, if you plug it in sooner you could damage the compressor.
Please give a good rating, it is very important to me. Thank you, feel free to re-contact
Aug 05, 2009 | Sub-Zero 632 / S
Sub Zero 650S with bottom freezer-Ice tastes funny(musty ? taste)
The 650 does not have a filter built into the unit. Any filter would be on the supply line to unit, usually in the basement below the unit, or under the kitchen sink. Do you use alot of ice? If not you may want to empty the bucket every few weeks to let it produce fresh ice.
Jul 21, 2009 | Sub-Zero 650 / O Bottom Freezer...
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
Sub Zero 632 leaking water
Had the same problem on the same model (632). Turned out to be a plugged drain tube on the condensate collection trough located on back wall of the refrigerator. Simply pull out the crisper drawer (the drawer below the lowest shelf) and you'll bee the trough. The drip tube can easily be plugged by a vegetable leak or grape, etc which had fallen into this trough. Hope its as simple for you as for us.
Sep 30, 2008 | Sub-Zero 632 / S
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Ice maker drawer for sub-zero 632
Look at both those tracks on each side. its likely one or both are cracked or broken. Each one has 2 screws holding it in. To put the metal hange back in the tracks, you must get new tracks (if broken/cracked) then hold the2 tracks onto the bucket carriage...then stick thewhole thing in as an assembly, hen put the 4 screws back in. there are 2 more small screws way in the back (one on each side), but they do not have to be removed, only there to guide the racks in properly. these tracks are only about 7 bucks apeice, and shouldn't take long to chamge. Good Luck!
Aug 02, 2007 | Sub-Zero 632 / S
Sub-Zero 632 / S Logo
2,745 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
