Question about Sharp LC-52D82U Television
No picture and i see fine color lines in horizantal and vertical lines. i also see Tv keeps flickering with very unusal way. This a new tv ahrdly 25 days old Any help apreciated
  • 103 Answers
These sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.
Posted on Mar 05, 2008
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Lg plasma tv 42pc3dv
you will have to have a tech come check that one out, your gonna need your y-sustain, z-sustain and both y-drive boards replaced.. its a common issue try to get your warranty extended if its out.
Apr 05, 2008 | LG 42PX5D 42 in. Plasma HDTV
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Vertical hold problem
Maybe sync separator transistor is faulty
Dec 22, 2007 | Zenith C32A26 32" TV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
No picture
hello,
this problem accure due to vertical o/p ic is failiur so plz checked it from any hardware engineer or if you changed it. you are welcome. i't mostly 9 pin ic on heat sink. it's mostly located at the horizantal _ vertical coil's wire( 4 wire attached with pcb) are placed.
ok
bye
Aug 30, 2007 | Samsung 21" FLAT CRT COLOR MONITOR
Vertical flickering color lines instead of pictures
Take your set to a qualified tech you have a bad vertical ic or some cap around the vertical section is not filtering the voltage properly and your deflection yoke could also be bad.good luck.
Mar 16, 2007 | Sony PFM-42X1 Plasma TV
Sharp LC-52D82U Television Logo
174 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
