Question about HP PhotoSmart C4280 Laser Printer
C4280 will not print in color
No matter what i do it always comes out black and white  i tried doing color matching and doesnt work  im using mac leopard  anyone know how to fix this
  • 1 more comment
  • tonyee Feb 28, 2008
    i did that and it stil comes out black and white
    it says standard and when i put it onto color matching it does the same thing just black any wihte
  • tonyee Feb 29, 2008
    not sure how to set b/w setting or color just plugged iti in  out of box
    Genius:
  • 3,587 Answers
No worries..start by getting new driver for that here
Posted on Feb 28, 2008
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Feb 28, 2008
    ok..so are the printer settings, after selecting the document, set for greyscale or b/w, which is a possible contributing factor.
  • Patrick Michaels
    what I'm asking here is whether the settings for the printer application is for b/w or color..
    perhaps a Shared Screen Session is in order?
    send an email to my contact listed on my profile, if you'd like an E Housecall
  • Patrick Michaels
    Patrick Michaels Feb 29, 2008
    ok..time for a shared screen service call..send me anote through contact info on my profile..this won't take too long
Printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
Sep 01, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Problem with printing black and white photos
Probably what happen is that you are printing black and white but you have your printer on color mode, try to set the printer to grayscale or black and white before print. The printer is tring to get the black and white by mixing all three color, that is the most comon way of make black, so, when one of the color is missing you see those red lines.
Also you will solve the problem replacing the color cartridge.
May 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
I want to only print in black and white in my HP Photosmart C6180
Jst go to printer and faxes in the control panel and,rgt click ,go to properties,click on color management and select print in black only.it should work fine.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Feb 17, 2009 | HP Photosmart C4280 Aio Printer
How do i Connect RCA VCR to Dynex 20" 480i tv
Ok yellow is always the video signel! and if you have a stereo vcr there should be yellow/red/white the red/ white are audio left and right! if your vcr is in mono then there will only be a yellow/white just use them and let the other red one hang free because it is not needed...if there are other color codes on your model just remember yellow is always the video(picture) the other are for sound and it does not matter where you plug them in at! If you have a black wire just use it in any audio input (red/white)
I hpoes this helps! if you need more help come see us
please rate answer!
Jan 24, 2009 | Dynex 20" Digital TV
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
Sep 30, 2008 | Canon MP610 Photo All-In-One Printer
Cant print black or do black and white copies
He's not saying that the black cartridge won't print (which would warrant cleaning the heads, or messing with the cartridges) -- I have the same problem that MarkDan is having as well... no matter what you select as the output from any "Print" dialog window, the HP 21xx and 12xx series printers _always_ print in full color. You can choose Black and White, Greyscale, Color -- doesn't matter what you choose in the dialog boxes, it utterly ignores you, and will always print in color.
I have no idea why it does this, but it's eating a _ton_ of color ink for no good reason. I have searched all over the Web and on HP's site, but solution has been found.
Jul 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Epson R2400 too red
i think you have a corrupted driver- you have to uninstall driver first
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
Go to print and fax and delete the printer name as well
Restart the Mac. (You do not need to empty the trash.)
If you have not done so already, please follow the steps below to download the latest driver for your printer in OSX:
1. Go to the following website: http://support.epson.com
2. Under the PRINTERS heading select INK JETS and then the Stylus Photo R2400.
3. Under the DRIVERS & DOWNLOADS section select MACINTOSH.
4. Select and download the following file for your operating system
which mac are you using? tiger ot leopard? intel core or powerpc?
May 15, 2008 | Epson Stylus Photo R2400 InkJet Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
How do I use only Blank ink on Epson R265
are you using windows or mac? on windows go to printers and faxes under control panel, right click on printer and go to printing preferences and under advance put a check mark on the box that will say grayscale or black ink only.
On mac when you click on file print go to advance tab and print setting, select grayscale or black and white.
pls dont 4get to rate the solution thanks!!
Apr 12, 2008 | Epson Stylus R265 InkJet Photo Printer
HP PhotoSmart C4280 Laser Printer Logo
70 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
