Question about Cameras
Good camcorder gone bad
I have a 1993 Memorex 158 moviecorder after leaving it plugged in a few months to its adapter I could not get it to function. It may have been a power surge that did it BUT there IS still power from the adapter and the battery. Contacts seem okay. I used an old multimeter to check voltages but am unsure of its accuracy it just shows that there is power. The camera will not function in any way. I have an 8mm tape in it but cannot eject it.
Should I try to have it fixed or just junk it and break into it to get my tape. I figure the camera might be worth $30 but it worked perfectly before this happened, I hate to throw it away. Hope you have some good advice for me.
thanks, Frank G.
    Problem Solver:
I've usually had to disassemble the cassette housing to extract the tape.
I have need of a remote for the model 158. Is yours available?
thanks
genemitchell@yahoo.com
Posted on Sep 20, 2009
Why wont my nookhd wont charge
If it\'s only two months old it may have a defective charging cable or adapter. If it\'s a new purchase and you can return it. To check to see if it might be the adapter and not the charging cable you have a few cheap ways to test this out.
General charging recommendations.
If you get power leave it on charge at least 3+ hours. This is the minimum time required if the battery is totally drained. If the Nook turns itself on during this process manually turn it off. The battery charges faster and more deeply if it\'s truely powered down. Charging more than 3 hours won\'t hurt it. In fact some manufacturers claim leaving thier products on charge for an additional hour after the charging light glows green is good as it leaves a slightly deeper charge on the battery. Also I believe leaving it alone for that hour allows it to cool the battery. Most manufacturers also recommend tottaly draining the battery at least once a month and then fully recharging it 1+ hours after charging light is green. They claim this helps the battery maintain a healthy charge and extends the battery life. Simply disconnect any charging cables, turn the unit on and just let it set. Don\'t touch it peroid just leave it alone until it turns off because the battery is totally drained. Then just plug it in and leave it. Only if the unit automatically turns itself on do you manually turn it back off.
Well that\'s about in in keeping the battery life and charge at its maximum.
If your AC power adapter has gone south there are only three ways to get around this. 1. Purchase a generic AC to USB adapter. 2. Purchase a genetic DC to USB adapter. Most of these can be cheaply purchased at most drug stores ect.. these days. You can even get DC to USB ones at dollar stores such as Dollar Tree. Good way to maintain your battery if your AC one goes south or you lose house current.
One other way to charge your battery is to plug the USB cable into your computer. Some manufacturers don\'t recommend this as this more often than not doesn\'t fully tank up your battery.
You can also get replacement charging cables at the same place you got the adapters. Places such as Walgreens, or CVS often have these at around five dollars a pop.
Apr 26, 2014 | NOOK HD 7 Tablet
I recently purchased a C4380 All-In-One and will be using it over the next few months in Europe. Can I simply use a plug adapter or do I need a DC power adapter?
No, you will need a step-up transformer (power adapter) and not just the simple plug adapter, as voltage in the US is 110V, while in continental Europe it is 230~250V. You can purchase this at any electronics shop.
Hope that helps. Kindly "accept" this solution if you found it helpful.
Thanks.
Jul 04, 2008 | HP Office Equipment & Supplies
Back up lights not working
auto or sticK? tranny?
you need a schematic, and FSM
the circuit is complex (why alludes me) im looking now
see page 108 and 158 here PPD pages.
http://www.jeep4x4center.com/jeep-service-manuals/Jeep_Wrangler_YJ/1993/Wiring_Diagrams.swf#pagemode=bookmarks&toolbar=1
so many connections...
the car with A/T has 2 backup switches.
the PRNDL (jeep is 1-2-D-R)
and a tranny mounted back up switch
both have 12v as inputs. and both can glow the reverse lamps
page 158
see Feed12, that is power.
see it feed both switches and the merge to the lamp feed.
why 2 switches, ive not a clue.
my guess, is its for redundancy.
if the PRNDL fails the real gear switch BU, works and lamps still glow.
so yours is busted 2 time.
Fuse 6 feeds The Feed12,
so use a voltmeter and check the voltages a page 158
a few tests there tells you, is the feed lost before or after the 2 switches.
Mar 06, 2014 | 1994 Jeep Wrangler
Memorex MVD2042 Unit worked fine yesterday, but today is not functioning. Standby light does not come on, and no functions work. The unit is receiving power (not an issue with the cord or power supply). I...
unplug from any power source. leave unplug for 15 minutes some capacitors keep power for a while so leave it unplug for a while. then turn back on. see what happens.
Oct 19, 2013 | Televison & Video
There is no power for the modem, but the power adapter is plugged in
Unplug the modem and let it sit for a few, then plug it back in. If this does not work, check your power socket to make sure it is live. There are times when the power adapters do fail. My main router adapter failed out of the blue a few weeks ago. I had the same experience, no power to the unit, even though it was plugged in.
If you electrical outlet has power, then I believe that your power adapter may have failed.
I wish that there were another answer. But, I would rather it be the power adapter that fails, as compared to the modem itself failing.
If you found this information helpful, please remember to leave positive feedback.
thank you,
Brian
Jan 16, 2011 | 2wire (1000-000057-000) Modem
I neet to buy or order a replacement ac adapter 5V DC (center positive) for my memorex Mi2290 travel speaker system. I am having extreme difficulty in locating one....the plug is small.....there is no...
Had the same problem. Called Memorex, they have discontinued making the unit and the plug. Stupid.
Went to Radio Shack. They sell an adapter, part number 273-333. It is an Enercell AC-to DC Power Adapter for 3/5/6/6.5/7/7.5VDC. Adjustable for the volts you need. The Mi2290 takes 5 volts. It comes with 3 interchangeable tips. The orange one fits the unit.
Don't be surprised, though. It was almost $30. Half the price I paid for the speaker. Cheaper than buying a new one, I guess. Hope this helps.
Jan 13, 2011 | Memorex Travel Speaker with iPod Dock...
Hp deskjet 6540 power adapter turns on but printer doesn't
This printer have a problem on HP circuit board. Usually its grounded due to ink waste, or not using it like what you said it took about three months. Here is a tip if your printer HP is still under warranty then you can send or contact to HP Center or the one you buy from it. To be sure that your printer is working back normally.
Sep 13, 2009 | HP DeskJet 6540 InkJet Printer
Today my cord for my toshiba was behind my pillow and i was lying on it. and I didnt notice, but then it showed that my laptop wasnt charging did my cord just get too hot? will it work later?
The power adapter does not have a temperature sensitive device, therefore it won't stop for overheating if not in consequence of a fault.
Try leaving the power adapter unplugged for about ten minutes.
In the meanwhile also remove laptop battery and put it back.
Connect it back to AC and laptop.
Ensure that connection to laptop and power cord connection to AC adapter box are both well plugged.
Before turning on laptop leave it connected for few minutes.
If laptop still does not turn on and battery does not charge, then the AC adapter is faulty.
A further test can be done using a multimeter to read voltage on AC adapter plug.
A replacement AC adapter is not expensive and can be purchased online. Try entering in Google your Toshiba model followed by the words "power adapter".
Aug 15, 2009 | Dell Inspiron 5100 Notebook
Ya i got a mp3 memorex
You just plug the usb into the memorex and plug the other part into the cpu...don't you read the instructions lol ?_?
Jun 27, 2008 | Memorex MMP8565 MP3 Player
Finalizing Disc
YOU HAVE TO MAKE SURE YOUR IN PLAYBACK MODE AND MAKE SURE YOU HAVE YOUR POWER ADAPTER PLUGGED IN
Nov 18, 2007 | Canon DC210 DVD Camcorder
Cameras Logo
55 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
