Question about HP Pavilion dv6000z Notebook
Help my laptop keeps shutting down
Hi, I'm trying to start this laptop but as soon as the Windows comes up it automatically shuts down. This is new laptop to me as previous user has moved jobs, so I haven't seen it working so far.
Any ideas what i can do? Thanks
  • Anonymous Mar 19, 2008
    my hp pavilion laptop shutsdown immediately after being powered up. up until now it ran just fine! whats up!!
    Novelist:
    Champion:
  • 256 Answers
Overheating is considered as one of the major causes of shutdown problems in laptops.
When any laptop runs, it generates heat and if it does not cool down, it may result in random shutdowns.
Thus, to get rid of this issue with your HP laptop, you should keep it on a flat surface and allow the fans underneath to work.
The use of cooling pads for laptops is also recommended.
This helps in removing the excess heat.
Get more information to fix HP Laptop shutting down error. Hope this helps you.
Posted on Jun 22, 2011
  • 57 Answers
What OS do you have?
Laptop shuting down can be so many problems.
reload your system there could be a virus
or you could have a bad hard driver
try to replaced your battary
memory could also be acting off
if possible, replace it. but I will reload pc first.
dont forget,make sure you have the org.operation software when loading to advoid driver location problem
good luck.
Posted on Feb 28, 2008
    Sergeant:
    Champion:
  • 317 Answers
Seems like it mioght have the blue screen of death. go to google, and search for a program called "Bart PE" download this program, run it and let it burn to a CD. Now, boot the laptop from this CD, and let it load. Now click on go, and find the command prompt. type in "CHKDSK C:/r" and let it run. once it finishes,l reboot and take the CD out. Now your laptop should work perfectly. Best of luck dude ;)
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
Acer aspire 4736g shut down unexpectedly
try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
Jan 17, 2013 | Computers & Internet
My HP G6o laptop keeps shutting down, says there was a problem with windows tries to restart automatically then computer completely shuts off?
See if you can hit F8 before it goes in to windows and pick start in VGA mode it might be the video drivers or a driver that is not meant for that laptop.
Feb 15, 2011 | Computers & Internet
Gy laptop keeps failing configure updates every time i turn my laptop on. its really annmoying me as every time i go to shut down, it keeps doing the same "installing 1 of 2 updates"
Hi ahzeal,
One thing you can do that make some changes in automatic updates. Just follow is these steps:- 1.Goto Start---->Run. 2.Type services.msc then hit enter. 3.Find out the Automatic updates or windows updates(in case of Windows Vista or Windows 7). 4.Change it to manual or you can stop that(Depends on your wish).
Oct 04, 2010 | Computers & Internet
My laptop automatically shuts down after i turned
My new dell inspiron 14r laptop with windows 7 is suddenly getting shuts down plz help me
Jun 20, 2010 | CMB T43 750 Notebook
Acer Aspire 5002WLMi PC Notebook Laptop shuts down automatically
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting2_bing.gif, close all programs and restart the computer as you normally would.
If this does not work you will probly have to go back to factory settings
May 13, 2010 | Acer Aspire 5002WLMi Notebook
Laptop wont boot on, it starts but turns off again
I'm guessing ou have windows XP?
if so you hae a corrupted regisry and need to boot from your Windows CD and at he first et of questions choose Eneter to intall windows, then F8 to continue and then it should tell yo another Windows insatallation has been found and ask if you wish to perform an automatic repair.
Give it a try and enjoy :)
Jan 22, 2010 | HP Compaq Presario CQ50-210US Notebook
IBM 2647 -41U automatic shut down
How old is your computer??? is it getting overheated?..what operating system did it have before xp? does it give you any messages before shutting down?
let me know
Apr 10, 2009 | IBM ThinkPad T20 2647 Notebook
Toshiba A135-S4527 will not automatically shut down
If you truly believe the problem happened right after installing the new mouse, then you should start by uninstalling the software for it. Go to Control Panel -> Software -> Uninstall. If this fails, you can use the System Restore utility to rollback the Windows registry to a time before you first installed the new mouse software. Have you tried to unplug the mouse and not use it, atleast on the attempted shutdown process?
Mar 22, 2009 | Toshiba Satellite A135-S4527 Notebook
LAPTOP SHUTS DOWN
Hey,
a few possible problems:
1. Bad power connector
Check the cables and your battery.
2. Virus
If you dont have antivirus I suggest you get www.avast.com download the home version.
3. Overheating
Does the laptop get VERY hot fast? monitor the temperatures.
If you are unable to solve the problem, id recommend to take it to a professional, it would be easyer for you and me.
Id recommend turning off automatic restart on failure.
Heres how to turn that off:
when windows is starting before the logo comes up, press f8 untill a menu shows up and select disable automatic restart.
if you do that you might start seeing some blue screens when your computer shutdown instead of just shuting down, these screens can be used to solve the problem if you get such a screen, type up the all the codes. Example 0x00000f1 (0x000000...)
Mar 17, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
1,430 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
