Sharp LC20B2UA; Blows fuse F3701. - Televison & Video
  • 2,336 Answers
Check the primary side of T3701 circuitry, Q3700 and S4701 for shorted condition.
Posted on Feb 28, 2008
  • Jaime Hernandez Feb 29, 2008
    When you asked for help, do you know yourself what you are asking or even understand what it means?
    The kind of information you provided it does not even mean anything to you.
    I tryed to answer what you asked and I was going to send you the schematic diagram but I guess, you do not know what that is eather.
My LC20B2UA dosent turn on only red light
It may have shorted out backlight circuits or problem in the 18~24vdc power supply section, the 5vdc is working though. It can also be the main logic board itself.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 04, 2010 | Sharp Aquos LC-20B2U 20 in. LCD Television
Changed the fuse but it blows again
check the horizontal output transistor for short.
Apr 06, 2010 | Sharp 25R-S100 25" TV
Sharp R8310 blows inside fuse when microwave
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
Info on ordering Sharp UK parts / spares is here.
May 11, 2009 | Microwave Ovens
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
Blown fuse
Check your door switches or your turntable motor, these could also cause the fuse box to trip.
Mar 25, 2009 | Sharp Microwave Ovens
Sharp Model 1451 blown power fuse
1.Problem with monitor door switch or
2. Problem with high voltage condenser.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 30, 2008 | Sharp R-1874 Convection/Microwave Oven
Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
Sep 02, 2008 | Sharp R-1460 Microwave Oven
replace the terminal pcb part # DUNTKB128DE03 you may be having a short in the secondary power supply. you can get the manual here https://www.vancebaldwin.com/shop/research_new/SHA/LC20B2UA.pdf to help you better trace the short. it can also be the main board too better to chase the problem than to make guesses.
Apr 19, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Fuse F3701 is blow-up after few munites turns on. If replace a fuse F3701 again, it work, but the set turns of any time, check the set: Fuse F3701 is blow again?
Look at the power board " the one with the fuse" for capacitors that look puffed at the top or leaking at the bottom. If these are leaky the voltage drop will cause the current to rise and pop the fuse. After a time the caps will get bad enough that the set will stop working and may cause more problems.
Apr 16, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
Oct 27, 2007 | Sharp R-963 Convection/Microwave Oven
Televison & Video Logo
290 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
