Question about Whirlpool Duet GHW9150P Front Load Washer
Dingy Towels I have the whirlpool duet front, load washer. When I first got it I was so impressed with it because my son gave me some of his towls to wash and they looked so much brighter and cleaner. But recently I noticed my towels are looking real dingy and dirty. Worse then what his did before I washed them. Is it my water or is the water level in the washer? There does not appear to be that much water in the washer, anyway not that I am able to see. I am using the same soaps as from the beginning when my laundry looked so bright and clean. So what's up with my laundry?
    President:
  • Whirlpool Master
  • 2,651 Answers
Check a few things , make surer your using an HE detergent, Liquid better then powder. water level rarly a problem with theses machines( they'd give a fault code if so).lastly they just placed a product on the market in the last few months . AFFRESH tabs, found at major appliance chains, specifically designed for cleaning out theese machines.
Posted on Feb 29, 2008
My washer is 2 days old. I selected the bulky level to clean a load of towels. The time showed 1 hour and 15 minutes . After 15 minutes, the bell rang and the code f08 and E01 appeared. This also happened...
Pull out the reciept. Read the info that came with it. Call for warranty service OR if possible, return it to store fro exchange or refund. Some appliances cannot be returned to store, therefore read blurb first.
Jan 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Was so proud when my husband brought home te
I wouldn't blame it on the washer but did you have the same problem with your previous washer? Are you using the same water source as previously. Do you use a chlorine bleach with it and did you use it before? Is the cheer a liquid or powder. You should us a powder.
Mar 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dingy Clothes
What is the answer for dingy clothes? I have the same problems and I'm getting ready to get rid of this washer because I'm tired of not getting clean clothes and having my towels smelly after taking them out of the washer.
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet baffle broke off under normal use part 3 818-2233
Please report your dissatisfction to the manufacturer.
Thanks!!
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool deut washer - is the a lint screen on washer like the top loading washing? If yes how do you clean and service the lint screen? Thanks.
there s a"button trap" located on the side of your pump assy, behind the lower acess panel ( youll need to remove 3 torx 20 screws from the from bottom of machine ) after emoving the panel oull see the clean out directly in forn t of you. BE WARNED THERE WILL BE WATER behind that acess point grab a towle!!!!
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
On whirlpool duet ,am getting fault code f21 in wash cycle.
Foreign objects in the prepump
remove access panel in front remove round plastic plug clear objects have towels ready
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need directions to unclog my Whirlpool duet washer which is giving me a f21 code.
Empty the washer and get some towels...
  1. Unplug the washer.
  2. Remove the kick panel 4-8 screws along the bottom with a Torx 15 screwdriver.
  3. Directly in front of you will be the pump and the cleanout (large twist-cap).
  4. Pack towels under and around the cleanout.
  5. Turn the cap counter-clockwise and pull out.
  6. Remove any debris.
  7. If you have an additional cylindrical pre-filter, remove and clean it.
  8. Re-assemble.
  9. Plug in the washer
  • Note: If you see bubbles or foam in the cleanout, you're using too much soap.
Dec 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer flashes P 2 and now SUD will not finish cycle
F-2 IS ERROR CODE SUD MEANS NOT USING H E DETERGENT,, REMOVE DEBRIS FROM PUMP AND SHOULD RESOLVES YOUR PROBLEM ,, REMOVE BOTTOM PANEL 3 SCREWS ONCE REMOVE PUMP FILTER RIGHT IN FRONT BE SURE TO HAVE ALOT OF TOWLES READY MACHINE STILL STORES 3 GALLONS OF WATER
Nov 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
CLEANING OUT CAT DANDER ETC FROM WASHER
Quenie, vinegar will not harm your washer at all. Place it in the detergent side of your dispenser and run a Hot wash cycle. Don't mix chemicals, though... if you choose to clean your machine with bleach, for instance, don't use additional cleaners along with it. Vinegar only, bleach only... you get the point.
You may want to run a "water only" Hot wash cycle with bleach (no clothing/towels) after your Son has finished his laundry. This may help alleviate your allergy problem.
For regular maintenance on your washer, you ought to try something like this. It'll keep your washer smelling great.
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal De
