Question about Sony Ericsson J230i Cellular Phone
Audio problem in J230i set
Getting a low speaker sound for fm alone... but the ringtone and headset sounds good....
  • mustydon92 Jun 30, 2008
    my bottons of down is no more working and have low spekers in radio
Just check your headpshone set pin connected to your cell phone...... that pin might have loosely connected.... i had same problem, i resolved by connecting it tightly....
Try it..... it may work for you
Posted on May 28, 2008
Why am i not getting any sound out of my lap top computer?
Try to connect an audio system or headsets from the audio/headset input. If there has sound coming out?. The speaker of your PC was damaged. If did'nt hear any sound? Update the sound driver.
Aug 26, 2014 | IBM ThinkPad Computers & Internet
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
No output to speekers Sony STR-DE825
Check that the mute is not on.If a headphone is plugged into the receiver the speakers will be muted.Verify the the output selector is set to the correct source.Here is a simple check.Select a strong FM radio station.Plug in a headphone.If you are receiving an audio thru the headset.Then disconnect the headset and see if the audio is transmitted to the speakers.If you still have no speaker sound check to see if the speakers have fuses which may be blown.I would try another set of speakers to determine if it's the amplifer or the speakers.The amplifer has fuses as well. Wiilbe inside if not at the rear
Oct 21, 2012 | Sony STR-DE825 Receiver
2009 flhtcu no sound from speakers just headset, light on speaker switch not working.
Sounds like vibration damage to the audio circuit. Verify the connection to the speaker switch. If all is good, radio will need to be repaired. Contact Iron Cross Audio (www.ironcrossaudio.com) for repair options
Oct 02, 2010 | Harley Davidson 426290 AM/FM Radio
Simultaneous audio through headset and regular speakers?
This is not possible with Windows. You would need to purchase a mixer program of some sort. The USB headset is seen by the Operating System as a stand alone sound card. Windows will not mix two sound cards.
Mar 07, 2009 | Logitech ClearChat Pro USB Headset
Model No.Samsung SGH J600
go to "settings" or "sound settings" (anything relating to sound settings or setting")
you should find volume control settings for increasing the ringtone.
if it is still low after doing through that process mybe it is time for you to change you sound speaker(they do normally get worn with constant use and would need a change)
good luck.
May 14, 2008 | Cell Phones
RCA Wireless headphone triggers off after 35 seconds of operation
ya the volume of your source is your issue.
if it is too low, the unit cuts out after 45 seconds or so...
crank up the volume and turn it down on your headset
Mar 16, 2008 | RCA WHP140 Consumer Headphones
No sound from my Logitech headset when on SKYPE
Maybe you need to select which Audio device you are using within Skype. It the Settings under Audio you should be able to select the default audio device that Skype talks to. If you set it to the USB headset, it might work properly.
Nov 10, 2007 | Logitech 250 Headset
Sony Ericsson J230i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
