FixYa.com
Tags:
Copiers
Generic problem for all Copiers
Black line on copies
posted by lit red on Feb 28, 2008
There is a one inch black line down middle of copies
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by drichards, posted on Feb 29, 2008
Black lines occur from a few things. You did not list the brand, model, or class of the copier. If its a PCU cartridge based system, the easiest way to tell, is to start making a copy, and as the paper gets about half way thru, shut it off, and pull out the PCU cartridge, and see if the strip is on the drum. If not. it is probably on the fuser.
Please give more info.
Solution #1
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If your copier has an automatic feeder and your line is present when using the feeder but not when you copy from the glass,just clean the small glass at the point where the line appears.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP 190 Copier Panasonic Workio DP-1820E Copier Panasonic Workio DP-2000P Grayscale Copier Panasonic (FP-D355DC) Copier Panasonic DP-C106S1 Color Copier Panasonic FP-7845 Black and White Copier Panasonic DP-8045 Grayscale Copier
Can you Help with these Copiers problems?
Sharp AR-5320 Black and White Copier
Sharp AR507
Oaccasionally the copier will... Answer This...
Copiers
no display - wont start up
wont power up - checked all... Answer This...
Canon PC-940 Black and White Copier
feed head does not turn
will not feed paper feed head... Answer This...
Brother Brother DCP 7010 - Multifunction (...
dcp 7010
dcp 7010 scanner locked error... Answer This...
Toshiba e-Studio 161 Copier Copier
Toshiba e-Studio 166 copier
Toshiba e-Studio 166 copier... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
