PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Keyboard stopped working
By snafus on Feb 28, 2008
my dell keyboard stopped working,this was after shuting my computer down because my mouse had stopped working, the mouse is now working,i have spoken to techs at dell no help as i have tried all they suggeted apart from taking the computer apart, i think i need driver for keyboard,but that is supposed to be in the computer but its not,both are usb, any help welcome.
Comments:
Feb 28, 2008
- firstly thanks, my computer is a desktop, although it thinks it's a laptop. It has only usb ports, I have tried a new keyboard this also dose not work, the usb ports are o.k as the mouse will work in any of them and the power light shines on the keyboard.
Feb 28, 2008
- THANKS, WIDOWS TRYS TO LOAD NEW HARDWARE, BUT HAS NO DRIVERS SO FAILS.
Feb 28, 2008
- If I restart without the keyboard no lights show and it is not recognised by the computer, if I restart with the keyboard attached the light shows, windows then trys to load it but there are no drivers so it fails. Just to keep you thinking.
Feb 28, 2008
- i am running xp, and as far as rating anyone, you are all wonderful and please keep helping as we need each others ideas as the so called experts in the call centers presume that we havn't a clue, but we only call them when we have tried everything else.
Feb 28, 2008
- I have only 8 usb ports, no PS/2 so could only try another usb keyboard.
Same Problem
Mar 24, 2009
-   my ibm laptop keyboard does not working and my operating system is crash why but every problem started after total keyboard not working plz give me best suggestion
-   Guest
Solution #1
posted on Feb 28, 2008
Somewhat Helpful)
Compurepair
Rank: Wiz
Rating: 84%, 784 votes
Try Swapping The Mouse for The Keyboard ?
you may have a faulty USB Port On The Computer/Laptop.
Also Which operating System Are You Using Windows 98/2000/ME/XP ?
Another possible Fix, is to wipe the USB Connectors/Contacts on the End of The USB Plugs. ( Computer And Keyboard ) use A Cotton Bud/Swab *****lightly****** soaked with lighter fluid/Petrol/methylated Spirits.
Mike @ Compurepair.
Comments:
Feb 28, 2008
- Hi,
Sorry abouit That, The Main Catergory is Laptops.
my final suggestion ( as you,ve already rated rated my performance )
Is to go into Control Panel/System/Device Manager. Towards The Bottom, USB Devices. Right click on everything USB related and remove. ( without Keyboard And mouse Connected )
Then at the top of the page, scan for hardware changes.
this will then re-find the USB devices. Then plug in keyboard and see if its detected. ( bottom right hand screen ) USB Device Found ( found new Hardware ) If none of this works, you could try re-installing your operating system, which will overwrite any corrupt or missing Files.
Good-Luck Mike @ compurepair.
Feb 28, 2008
- HI,
which version of Windows are you using ??
re-install the operating system. start the computer with your windows CD in the Drive.
Don,t be too hasty to rate someone trying to help you, unless they stop helping you.
Mike.
You can Pay $19.99 For premium assistance.
If you want a quick Fix.
Feb 28, 2008
- Sorry,
Don,t you have another Keyboard ( PS2 type )
I think your problem, is that your Draining your Computer, by using Too Much USB Devices.
Get rid of the Mouse Or keyboard.
Mike.
Feb 28, 2008
- Hi,
i don,t need the Experts.
i am an expert, i,ll build-repair Computers No Problem.
Yoou need to get another keyboard Or mouse.
Too Much On USB ( Draining The Power Supply Unit ) on Your computer.
thanks For your help :)
Mike @ compurepair.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
RimCmputr
Rank: Apprentice
Rating: 84%, 6 votes
you could try getting a USB to PS/2 adapter, if you have a PS/2 port on your computer. if it is a Dell made in that last 2-3 yrs ir probably doesnt have PS/2. its worth a shot tho.
PS/2 ports are usually Green and Purple. if you do have two, you might go to your local Radio Shack and see if they have any. Let me know if it works.
About the driver, there is no driver for the keyboard, except the generic USB keyboard driver in Windows.
If the keyboard is truly dead you might just go buy another one (or trie to get one from Dell, if its under warranty).
Comments:
Feb 28, 2008
- is there another computer that you could try this keyboard on? of so, you may want to try the keyboard on that one. otherwise i'd do like Compurepair said and reinstall Windows (not reformat, reinstall, or repair).
But he may be right in that it is draining your power supply, i kind of have my doubts as Dell puts in PSUs with enough wattage for the amount of USB ports and system devices.
And as to being an expert, i also am an expert.
Best of luck to you.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
took apart, cleaned fan, put back together. plugged in. 3rd light from left comes on briefly then... (More)
Answer
webcam in compaq presario CQ60 not working after installing vista, i installed drivers from compaq... (More)
Answer
M305-S4815 screen went blank and will not come back on. Tried recovery disc but nothing appears to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
