Question about Magellan RoadMate 800 GPS Receiver
Recharging problem The DC pin is loose on my roadmate 800 and I am having trouble finding a replcement to correct my charging problem.
  • Alm51158 Feb 29, 2008
    I soldered the contacts to the visible pins but it's not strong enough to hold during regular use and eventually will snap off again.  I am trying to find a replacement DC pin for this problem but the Magellan company does not sell parts but they do charge for repairs.
Just wrap the aluminium foil (kithchen foil for food wrap) around the pin and it should be tight enough to make contact and grip, as its aluminium metal it will allow the electricity to pass on... and your device gets charged.. only point is if you keep on removing the plug and re connections... if just keep it always connected , this trick should solve your issue.. other wise try to glue the alumininum foil to it self by gluing at overlapping one end on the other end.
make sure the foil doesnt go in front( ahead of the charging pin tip, other wise if it may enter inside the tip and both + ve and -ve poles get connected , which may spoil the devices).. hope it solves your problem
Posted on Feb 28, 2008
Sony walkman NWZ-S754 Recharge is through computer - but can I recharge it via mains or in car.
Yes you can charge your player through main. All you need is a converter which connects to the usb cable to the plug. They are available in the market so you will need to look for it. Or you may find it at any electronic store.
Jan 20, 2011 | Sony Walkman Video NWZA818 MP3 Player
Can I charge my Magellan roadmate with USB cable connected to the computer?
It depends on the Roadmate that you have. :
- If your Roadmate has a separate plug-in port for charging your unit IN ADDITION TO a USB port, then no, your Roadmate cannot be charged using your computer via the USB cable.
- If your Roadmate only has a USB port available for charging your unit, then yes, you can charge it via your computer via USB.
However, please note, according to Magellan, charging your unit using your PC via USB can take up to 12 hours to charge vs. 4-6 hours when using the vehicle power adapter.
FYI: This is mainly due to USB constraints on pretty much all electronic devices. USB cannot carry the same amount of power to a device. It uses what is commonly known as a 'trickle' charge to recharge a device. It carries much less current than a full-blown charger (like an AC power adapter).
Apr 18, 2010 | Magellan RoadMate 1340 GPS Receiver
I have a legacy item (Roadmate 800). The battery was dead so I ordered a new one. The new battery powers on the unit but when I plug in ac charger I don't get a solid orange light, but a flashing green...
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Feb 07, 2010 | Magellan RoadMate 800 GPS Receiver
My gps needs charging but the charger isn't working, the connection from the charger to the gps is loose.
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040 4050and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 12, 2009 | Magellan RoadMate 2200T GPS Receiver
My magellan crossover gps keeps shutting off in navigation mode - why?
make sure its charging..plug it in to a known good charger..go to the main menu, then systems options then power the power bar on the bottom should be moving from left to right..if its not, its probably the dc power port
If your GPS is not charging, the following models are known to have faulty power ports.
Magellan Maestro or Roadmate..800 860 2000 2200t 2500 3000 3050
3100 3140 4000 4040 4050 6000t
you can buy a power port HERE
or get it repaired HERE
bill
Oct 01, 2009 | Magellan Crossover GPS
Magellan Roadmate 300T, bought new battery but it wont charge.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc powerport...i sell these power ports and will repair them for anyone thats notable to do it themselves.
you can get it repaired here
Sep 03, 2009 | Magellan RoadMate 3000T GPS Receiver
Female receptacle for power cord is damaged.
We have a Maggelan Roadmate 800.
The pin that charger connecte to is missing.
Can you help please?
Rgards
M Daneshvar
Glenwood, Bracknell Road, Warfield, Bracknell RG42 6BH
Telephone: 01344 883051 mobile: 07768 916053
Fax: 01344 886756
Email: PolyDevelopments@aol.com
Mar 16, 2009 | Magellan RoadMate 800 GPS Receiver
Output voltage
Hello rcgibson, output of charger for (if this is correct 'Roadmate 800 GPS unit) AC wall power supply or 12/24 volt DC is 5 volt at 455 milliamp.
Oct 24, 2008 | Magellan Universal Ac Wall Power Supply...
Pin stuck in charging jack!
It is broken, you are going to have the DC jack replaced.
Dec 27, 2007 | Acer Aspire 3680 Laptop
Magellan RoadMate 800 GPS Receiver Logo
50 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
