Question about HP Compaq nc6000 Notebook
Re: HDD replacement
I have a HP Compaq nc6000 laptop with a bad harddrive(it failed the check disk utility in bios) when I replaced the harddrive I receive an error 'no system disc detected'. Is this because of the Drivelock on the PC? Do I need to unlock the old HDD before I install the new, or is it just a matter of modifying the bios?
  • beener_g Feb 28, 2008
    After installing the new HDD I entered the bios and changed the boot sequence to look to the Multibay first and the HDD second. I then placed a copy of the operating CD (Win2000...The original XP restore CD is MIA) in the drive and boot the machine...then I receive the 'no system disc detected'
    The bios doesn't display any HDD information...the old HDD is a 40GB and the new HDD is an 80GB both with an ATA6 interface and 5400rpm.
    I have tried installing the jumper from the old drive since the new drive didn't come with one and still the same result.
  • 520 Answers
Go into bios on power up . set boot options boot from cd first.save settings.restart,make sure have operating disk in drive .when instructed press any key(to start from cd) pc will check and find that there is no partion or system.create partition,format partition and install new system(windows)
Posted on Mar 01, 2008
  • 57 Answers
Set the jumper on the HD as it was on the old one
can you see the HD when the system boots up
are you using window vista?
if there is a driverlock on your pc yes you need to unlock it.but this should not be a problem.
what size hard driver was there and what size hd are you trying to use.
check your bios setting. this can help
Good luck
Posted on Feb 28, 2008
  • 108 Answers
If you have replaced the HD - this drive will be completely blank.
Your computer needs an operating system installed.
If you got a system restore CD/DVD with your computer - this is a good time to insert it and follow the onscreen instructions.
Alternatively if you have a windows install disk then this is a good time to install it.
Its also likely that everything on the old hard disk has been lost.
However - At a later date you could try and add it as a Slave disk to see if you can recover your documents etc once you have your machine up and running on the new disk.
How do I replace a NC6000 laptop lid catch?
HP Support > HP Compaq nc6000 Notebook PC > Manuals download page > Service Manual,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodSeriesId=367367#3
Click on -
HP Compaq nc6000 Notebook PC - Maintenance amd Service Guide
Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds before the first page comes up.
(PDF file doesn't show until it is fully downloaded)
This is a temporary download. If you want to save it to your computer there is a way.
This way you can copy it off to a CD disk, and after checking to make sure it is a good copy; then delete from computer to save harddrive space.
http://www.insidemylaptop.com/replace-web-camera-in-hp-compaq-6730s-6735s-notebook/
http://www.insidemylaptop.com/disassemble-hp-compaq-6730s-6735s-notebook-remove-cooling-fan/
http://www.ebay.co.uk/sch/sis.html?_nkw=HP+Compaq+nc6000+Laptop+Lid+Catch+Latch+Clip+
Regards,
joecoolvette
Mar 09, 2013 | Computers & Internet
Just replaced my hdd on Compac Presario 2100 but the system is not detecting it.
This model laptop came with a 60Gb hard disk and if you installed a much larger capacity hard disk then the BIOS cannot detect this hard disk.
For the BIOS to detect a large hard disk a BIOS upgrade is required (if there is one available) Check the HP/Compaq WEB site to see if there is a BIOS upgrade.
If not the try a 120Gb or smaller capacity hard drive.
As an alternative -
You can keep the existing hard drive in your laptop and use an external USB hard drive to store your data.
Nov 10, 2012 | HP Compaq Presario 2100 Laptop
I have a NC6000 whose hard drive stopped working and I replaced the hard drive and I could not get the software to load. I replaced the motherboard and now it will load but it still is not loading al
hi,
please check whether the hard drive is loaded properly into the computer.Turn on the compupter try to go to the bios of the computer and there do the harddrive long test.if the test is failed then the harddrive has gone bad.if the test is passed then try to install the operating system with a recovery cd's.if you don't have the recovery cd's then you need to call HP to get the recovery cd's.
Nov 15, 2011 | HP Compaq nc6000 Notebook
HP compaq NX9420 fails to boot up; complains about system disk and i tried to install Windowsxp but it switchess itself in the process of installation
Hello Dear,
If you tried to install the windows XP on a failure HDD then it will behave like this.
You need to check your HDD first, Go to your BIOS and run the HDD Self test.
If it successful then Just format your HDD before installation it should work.
If it failed then you need to replace your HDD.
With regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Oct 11, 2010 | HP Compaq nx9420 Notebook
Hi,My HP Compaq nc6000 just developed a problem of not coming on. I have checked the battery and its okay. I have blown its internal parts and it remained off. It only indicates the orange light for some...
try taking the battery out completely and see if the laptop runs of the main power from the outlet, if so then the battery may have a bad cell in it and would need to be replaced.
Primary Batteries
6-cell Lithium-Ion (4.4Ah) – standard
8-cell Lithium-Ion (4.4Ah) – optional
Power SupplyExternal 65 watt AC adapter
from looks of it the battery has gone bad
http://www.laptopbatterystore.com/product/2151/compaq-business-notebook-nc6000-batteries?utm_source=GoogleProducts&utm_medium=CSE&utm_campaign=Compaq/HP&utm_term=HP18S6-Compaq-Business-Notebook-NC6000-Battery
Aug 20, 2009 | HP Compaq nc6000 Notebook
My hp compaq nc6000 says nonsystem or disk error wont go further?
If you get an error message - non system or disk error and the hard disk is not detected in the BIOS, then you most likely have a faulty hard disk and chances are you have also lost all your data.
If you are desparate to recover your data, there are data recovery companies that can retrieve data from faulty hard disks but it will cost you an arm and a leg for their services.
To get you computer operational again, you will need to replace the hard disk and install Windows, all the device drivers and your programs.
Jun 02, 2009 | HP Compaq nc6000 Notebook
Compaq armada sb nc 1000 problem
Common with old compaq Laptops, when the HDD Fails generally it takes time to get into BIOS ( may be not ), Problem, stumps down to NO HDD , try to check the HDD Bay , check for the noice from HDD..you can do DOS boot (win98) from CD or Floppy and do FDISK...if it shows HDD , not much to worry it not ....finally you may need to replace the HDD.
Hope ti helps....Keep the hope :)
May 19, 2009 | Compaq Computers & Internet
Compaq Presario C304NR STOPS LOADING AT COMPAQ LOGO
It sounds like the hdd has failed. When you try to boot can you hear the hdd attempting to spin up? Best solution if everything else checked out would be to replace the hdd. Hope this helps & please remember to rate my answer. Thanks.
Dec 31, 2008 | HP Compaq Presario v3000z Notebook
Non System disk
a) remove any external devices and reboot.
or
b) boot from Windows XP setup-cd into rescue-terminal, execute: fdisk /mbr
or
c) do a hdd self-test in bios (restart, press F10, tools --> hdd self-test option --> notebookharddrive) to check the integrity of your harddrive
Sep 21, 2008 | Compaq tc4400 Tablet PC
HP Compaq nc6000 Notebook Logo
294 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
