Question about Samsung HLR5067WX 50" Rear Projection HDTV
Picture freezes sound stops screen goes black for 30 seconds recycles over and over
Samsung HL 5067w. picture freezes, sound stops, screen goes black, set continues this untill power is unpluged, repluged sometimes plays OK for the rest of the day if it does not ,unplug again and again untill set operates normally . Samsung Tech says either the DMD board or complete light engin needs to be replaced. Today and other days it is 69 or 70 degrees inside the house set came on normally and has operated flawlessly for the last hours. No problems what so ever, is there a relay that is HEAT sensitive and causing the problem. Or does Samsung dlp sets have a built in fault that they are aware of but keeping from the public. The set is 24 months old and has had the on off problem for at least 6 months.
  • 4 more comments
  • DLPTV Feb 28, 2008
    I need an exact cure to my problem before I shell out 1800.00 to a Samsung tech.
  • DLPTV Feb 29, 2008
    Now this sounds like a real plan.Today Feb. 28th the set came on as normal no problems, it was colder in the house than normal 69 --76 is the 24hour normal, this is the second time this month it has been colder and the second time no problems occurred. The set stayed on 8 hours and then froze and went blank. Cut the power to the set 3 times and back to normal operation. I just cant get passed a module working and then not working, that is why I'm looking for some sort of power relay.
    I have the faith in the tech not the parts, I'm looking for a complete fix that will last.
    I have contacted Samsung and can not get them to even give me a hint as to what the problem might be. They did tell me to cut the power to the set and then wait several minuets power up and this might solve the problem. They are partly right, so they must know what the problem is. I'm looking for a lasting fix.
  • DLPTV Mar 07, 2008
    Today 3/6/2008 the DMD board was replaced, Wrong guess, I spent 800.00 no results, exact same problem. Unit freezes , no sound, goes black, might restart in 30 seconds and then again might not.
    Today 3/6/2008 Samsung tech came to replace DMD I spent 800.00 no results. I ask him about "N" boards and he told me Samsung has NEVER given a letter to identify any of their boards. He did say all of the other manufactures use a letter ID system but not Samsung. I did call the 800 number but could not the higher up's with the prompts you posted. I would appreciate any names of higher up's that you happen to know of. The tech left it with we will have to farther research the problem,and it will cost more.
  • 4,889 Answers
T sounds like the digital board, and not the DMD itself. Samsung knows there is a failure history with these "N" model boards. Call 1-800-SAMSUNG prompts 2, 1, 3, 1 and be very persistent. Get past the first levels. You wouldn't be the first person out of warranty to be offered a newer model for the cost of shipping. Good luck!
Posted on Feb 29, 2008
  • eagle338
    eagle338 Feb 29, 2008
    Well here it is then... your digital board is a toast and needs to be replaced... Its not the DMD board and i am sure about this...
  • eagle338
    Your digital board controls the power supply as well... Its like a control unit. From what you have said it is cutting off the power supply at will! Thats why you see these abnormal turn offs.
    Regards,
    Eagle.
  • 2,322 Answers
Base on what you have described on your post, I would say that the TV may have some cold solder joints or leaky capacitors most likely in the power supply area.
Ask Samsung if the have some sort of firmware update for this TV set and hopefully they can tell you at least that part, but I would not be sure the firmware update might fix the problem.
I would not recommend to try to get into service mode because you will need the service manual for it.
Let me know if you need more assistance.
Posted on Feb 28, 2008
    Scholar:
  • 110 Answers
Hiya DLPTV!
I don't see any reason not to trust the Samsung tech on this. It *is* likely that there is a safety relay in place to prevent the damaged component from causing collateral damage, and no, Samsung wouldn't make it public, just as they don't make the service menus public.
My recommendation? If the repair will cost $1800, sell the set off for parts and get a brand new 1080p DLP set for less.
    Guru:
  • 1,894 Answers
Think you power board is bad
  • dewan nafees ahmed Feb 28, 2008
    your DMD board is only faulty
    you will have to replace it for surely
    thank you
    good luck
    dont forget to rate the solutions
    what i feel is ...only the DMD board is the problem....
    else make it your wish....
    anyways good luck
    thankyou..
    regards....
    sweet_rascal
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
? 3:16
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLP5063 the blue and green seem misaligned
you have what they call guns in the back of the tv blue/green and red and sounds like they have came out of adjustment. as far as the picture being black and white you should get a tv technician to check it
Aug 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP HL-R6167W - works fine for about 5 seconds then the screen freezes, sound goes out and then goes black then comes back on by itself and repeats the whole process. No blinking error lights.
There are three possible parts causing the problem. First, the Main or Digital bd is bad, Second, the DMD bd is bad. Third the Color Wheel is bad. You need a trained Samsung tech to have a look at it.
Jul 12, 2009 | Samsung HL-R6167W 61" HDTV
Lost Picture
Need new balast and lamp
Sep 02, 2007 | Samsung HL-R5677W 56" HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
95 people viewed this question
Henry  Thomas
Henry Thomas
