Question about Kenmore 22422 Top Load Washer
I have a Kenmore top load washer Model # 22442100, type #111. The wringer won't spin. The agitator works just fine, but I've been having to wring all of my clothes out by hand. Is there a way that I can fix this problem??
  • 1 more comment
  • Anonymous Apr 25, 2009
    everything works fine except the wringer. I usually redistribute the clothes and end up using 3 spin cycles to get most of the water out. Also, there is a lot of water left under the tub, even when I spin an empty load.
  • tbug502003 May 11, 2010
    I have held the switch with the lid open and watch the spin cycle and i just don't think it is spinning up fast enough to remove the water. Like I said if I remove some clothes and go through the spin cycle again it will remove the water out......
    I have a Kenmore top load washer Model # 22442100, type #111. The wringer won't spin fast enough to get all the water out and this is with a light load. If I take some of the cloths out and run it through the spin cycle again it will spin up fast enough to remove the water.
  • 156 Answers
Yes there is ck the lid switch make sure it works that usely the problem 99% time
Posted on Mar 03, 2008
Kenmore Washer Will Not spin
replace door switch ,good luck APPLIANCES R EN
Mar 03, 2013 | Kenmore Washing Machines
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Some times the washer machine will spin and then
sounds like your clutch is slipping,,,,you can put a #10 washer in one of the clutch spring caps and that stops the slipping! thats a low on cash fix or just replace the clutch ,cost about 40 bucks!
Mar 30, 2010 | Kenmore 22422 Top Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator not working properly
remove the agitator cap there is a 7/16 bolt in the top of the agitator remove it remove the agitator there are 4 little plastic teeth like pices in the top of the agitator call agitator dogs they are warn out. seperate the agitator remove and replace the dogs then put back together machine should work fine
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Unit filled, but now will not operate
so it dosent make any noise?your lid switch will stop it from draining and spinning but it will agaite on most kenmore waskers.if i came to repair that would be my starting point
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
806 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
