Question about Zanussi 18 in. ZSF4123 Slim-Line Free-standing Dishwasher
Water not heating
The machine goes thru the program but the water is not heating up & its not drying
  • chopsy1 Jun 15, 2008
    machine goes thruogh cycle but water not heating up.
    thanks for any advice.
Water not heating
Posted on Jan 26, 2009
The light goes on. I can feel the water is heated. Machine makes a lot of noise, but water doesn't pass from resivoir thru to frother wand or thru coffee filter. I am just running water to te
It needs to be descaled. After that, turn and try to make coffe but without the cofee. Turn on the steamer nozzle at the same time, that will draw the water to the coffee area, in fact try that first.
Dec 09, 2014 | Cuisinart EM-100 1000-Watt 15-Bar Espresso...
Hotpoint WF430 wont heat water
could be still clicking if faulty best thing get diagram for water level censer and do a test under 10amp load, thermostat next to element or contacts in timer melted or dry joints Re: Jeff
Apr 12, 2012 | Washing Machines
Whirlpool GU 2400 : "clean"
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Hope this helps... Please post back if you need more information.
Daniel
May 05, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
After starting dishwasher to do a normal wash with heated dry, the dishwasher stops and Clean light blinks 7 times, pauses and this continues until I reset the machine. After reset it goes to rinse only...
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn’t work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Please post back for further assistance.
Daniel
Aug 20, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
The heat is not hot enough to dry clothes half load
A dryer either heats or not heat . You have a vent blockage or vent hose kink . Pull the dryer out and remove the vent hose . Dry a load and see if it drys ok . If so , check the vent if it goes thru the wall to outside , or if goes up thru the ceiling , may have to get a cleaner ( line and brush ) at Home Depot .
May 02, 2010 | Whirlpool LGB6300 Gas Dryer
Haier XQG50-11
I had this same problem. There are two possible solutions. First, you need to look underneath (use 2 people) and see if any hoses are kinked. If that is not the case then the machine is pulling in too much water during the dry cycle. I'm hooked up to a sink so I just turn the faucet down until the water is just a trickle. This works for me. If yours is attached to the wall you need to turn down the cold water tap. Its a pain in the ****, but I discovered no one can fix this machine, not even Haier's recommended service A&E. I always know more than the repairmen, very sad. Hope this helped you.
Oct 31, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Jennair dishwasher timer stops halfway thru wash cycle.
Try using a cycle that doesn't boost the heat. Usually a quick or china/delicate cycle. Any cycle that heats the water pauses the timer until it is done. Some machines even select this with heated dry. The sensor that controls this can go bad and stop the timer completely. If it operates for the complete cycle , look for the sensor and replace it. There is usually a wiring diagram somewhere in the machine sometimes in an envelope inside the door, control panel or behind the front bottom panel
Jul 04, 2008 | Dishwashers
My drier dos'nt dry my washing
Is it pumping out the water?
try laying the draining hose on the ground or a bit lower than the machine if possible.
Jan 15, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Water Tank
There is a heating element much like a radiator inside the handle unit that is clogged. The water travels from the tank thru the heater and back down to the jets. You'll need to take the heater apart to clean it. You may need to check the hoses to and from the water pump also.
Jul 09, 2007 | Bissell 7950 ProHeat Upright Wet/Dry...
Zanussi 18 in. ZSF4123 Slim-Line Free-standing Dishwasher Logo
334 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
