Question about Aiptek R-PKDV58 Flash Media Camcorder
Camera not working
My camera wont turn on at all. one day it was working fine, the next it wouldn't even turn on
  • 1 more comment
  • CaliGirl101 Mar 28, 2008
    I have the same problem! I just charged it today and it wont turn on at all. I need help also.
  • rynedh Aug 07, 2008
    Battery power won't work but USB will. I suspect circuit failure. Wouldn't it be nice if someone would post an answer.
  • glen_9887 Dec 19, 2008
    camcorder makes a constant humming sound and does not work.
I took the camera apart and located a wire that had come loose, re-soldered the connection and the unit is now functional.
Posted on Sep 25, 2008
Same problem here too
Posted on May 17, 2008
My Trane XE1100 air conditioner won't start at all, worked fine one day and the next it wouldn't come on
check breakers in breaker panel,I need more info.is it blowing air inside
Jul 01, 2013 | Heating & Cooling
Replaced distributor in 2000 nissan quest ,now van wont start
check if there is spark in your plugs, if none, just replace ignition coil.
Jun 10, 2013 | 2000 Nissan Quest
Pontiac g6 drive the car a bit went somewhere got out came back 2 hours later all it did was turn over an wouldn't start has plenty gas left it alone for a bit try to start it it fired right up. So I...
flassed less engine power wth????????? Flashed reduced engine power ! Electronic throttle control problem ! Your best bet ,take it to a GM dealer , buick , cadillac , GMC . You do not have diagnostic test equipment or knowledge to even diagnose this.
Jul 06, 2017 | Cars & Trucks
My 98 Sentra does not turn over
Has the battery been load tested? do that first.
Apr 30, 2017 | 1998 Nissan Sentra
The car dies out, it will turn over but wont start, it ran one day then wouldn't
It is probably one of three things. It isn't getting a proper spark, proper fuel, or proper compression. Good luck!--------------------------------------------------------------------------
VAS 5054A
Dec 17, 2012 | 2006 Kia Optima
98 Ford F150 w/4.6l Wont start. Hear fuel pump click. Have pressure on fuel rail. Pulled #1 plug from head and plugged back into wire. Grounded plug and cranked. No spark. Changed wires 4 and 7 four days...
have diagnostic codes checked to see if you have a cam or crank sensor fault. make sure fuel pressure is at the required pressure, just testing to see if you have fuel at the valve is not enough. replace all spark plug wires. if you replaced two then all are just as old and even when they "look good" does not qualify as "they are good". Replace coil pack. start up drive away happy
Sep 05, 2011 | 1998 Ford F150 Regular Cab
It wont turn on..
camera lens are outta place :D
Nov 02, 2008 | Samsung Digimax S730 Digital Camera
I can't turn the camera on anymore
I dont have a definite solution, but I would;
- clean the power contacts on the battery and the camera with a moist Q-tip
- leave the battery out for a day or so, maybe more if you have time. Make sure the battery is charged again (maybe just put it on for an hour or so) and re-try.
Sep 19, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Camera no longer turns on.
Try polishing the battery contacts in the cover try ditt in the bottom of compartment with a cotton bud -or time for next camera
May 09, 2007 | Samsung Digimax 370 Digital Camera
Aiptek R-PKDV58 Flash Media Camcorder Logo
106 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
prouddad_1
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
