Question about HP Pavilion dv6000z Notebook
Hp 4600 laptop
Pressing the power causes a few lights to flash on but never powers up.
Same problem good Battery Good Power source Lights come on won't boot up. Happened while I was using it screen went black and computer became unresponsive. Just before that the touch mouse pad stopped working and I had to connect an external. Thought it might be hibernating but momentary push of power button doesn't work and I've cycled through Fn F4 to
  • Jetboy705 Feb 28, 2008
    Actually found a solution on an HP website it suggested removing and reseating the RAM before taking it anywhere. It worked. It was not very hard. Two screws on the back in the middle remove the door and the two sticks of Ram were right there one on top of the other a little overlapped. Each one is help in by 2 little metal tabs. Just lightly pull the tabs outword and the Ram pops up and you can gently pull it out of its slot. Repeat this with the other one as well then reverse the procedure and reinstall them. It took me 5 minutes and fixed what seems to be a fairly common problem with this model.
Disconnect the AC Power cord and then hold down the power button until the laptop cuts off completely then hold down the power button again until the laptop either comes on. This is done for about 15 to 20 secs.
Posted on Jul 18, 2013
  • 3,587 Answers
Hmmm...try it with the battery removed only on AC power..
Posted on Feb 28, 2008
Compute turns on, lights light up, and fans move, but there are no beeps or bios showing up.
Computer turns on but no display. This issue is commonly caused by electrical static on the motherboard. Try doing a power drain.
If this computer is a laptop:
1. Turn the computer off by pressing the power button for a bout 5seconds.
2. Take the battery out of the computer.
3. Unplugged the ac adapter.
4. Press and hold the power button for about 30 seconds. (without any power source)
5. Put the battery back in and plug the ac adapter back into the computer.
6. Turn the computer back on.
If this computer is a desktop:
2. Unplug the power cable from the computer.
3. Press and hold the power button for about 30 seconds. (without any power source)
4. Plug the power cable back into the computer.
5. Turn the computer back on.
Thank you for choosing FixYa! have a good one!
Jun 02, 2011 | Computers & Internet
Hi ive got a HP Pavilion dv6000 laptop with a black screen ,i have tried a external monitor and i have checked the ram but still black screen ,the lights are on and the fan is running..please help
Just try to power cycle the unit by removing all power sources (battery, ac adapter) and pressing the power button for at least 15 seconds. If this will not work and you did not get an image from the external monitor, then you need your motherboard replaced.
Good luck.
May 19, 2011 | Computers & Internet
Laptop will not turn on
Consider taking it for repair. The most common cause of this sort of problem can be: Bad capacitors (Bulging top/leaking) Blown resistors, diodes, transistors (They normally leave a black mark) or a fuse inside.
Apr 11, 2010 | HP Pavilion dv6000z Notebook
Hewlett packard 6735s power up
Your battery is critically low. Didnt you recharge your battery? Try turning it on with the external power source connected.
Jan 14, 2010 | HP Compaq 6735s Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Laptop wont boot and the battery and power lights flash
a simple power cycle might work. Take out the battery but keep the ac power connected. hold the poewr button down for 1 minute. then hit the power button again and it should poewr back up. If this doesn' t work. iyou said hte battery light flashes so the problem isnt the battery..the problem might be hte ac power adapter..if you have a warranty this would be a good time to call them. Try the power cycle first though this fixes the problems lots of the time
Apr 15, 2009 | HP Pavilion dv1000 Notebook
All three lights are flashing on my HP Deskjet 6127. I tried unplugging it from the power source and then plugging it back in. When I try to turn it on all three lights flash and it won't turn off with out...
The HP Deskjet 6127 has four buttons and three lights on the front panel
Flashing lights on the printer indicate the status of the printer
When all the lights are flashing, the printer may need to be restarted
try this 1st press the power button to turn off the printer, and then press the power button to it back on very quickly.
2nd press the power button to turn off the printer and hold it down.
Good luck
Jan 29, 2009 | HP DeskJet 6127 InkJet Printer
Laptop won't start up
Same thing for me 17 months old and normal usage
Dec 01, 2008 | HP Pavilion tx1220us Tablet PC
HP Pavilion dv6000z Notebook Logo
367 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
