Question about HP Business Inkjet 3000 Printer
PRINTHEAD ALIGNMENT FAILURE
We cannot get this error to go away. We have tried everything that HP.com support has told us. Any suggestions?
  • Anonymous May 15, 2009
    I have the same problem and just installed a new yellow printhead! Help
leroyal
  • 2120 Answers
SOURCE: HP G85XI Printer
Replace both ink carts with GENUINE HP ink carts.
Posted on Mar 10, 2009
APremkumar
  • 564 Answers
SOURCE: alignment failure
open the access door at the top of the printer
Remove the ink cartridges
Put your finger in the upper left corner of the printhead ( inside)
you will feel a small latch rigth there push it upward
the printhead will loose and you may now remove the printhead
Thanks, PREM
Posted on May 24, 2009
APremkumar
  • 564 Answers
SOURCE: Printhead alignment fails
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on May 26, 2009
  • 96 Answers
SOURCE: Error message reads
there is an issue with your carriage assembly. it cannot move freely across the carriage rail assembly. the belt may be worn, lubricate the rail assembly or both.
Posted on Nov 30, 2009
SOURCE: PRINTER REPORTS 'INK SYSTEM FAILURE'
1.Press '*' key on the key pad, then press the '#' key and release them both.
2.Then enter '123' to enter maintenance mode.
3.then press the right arrow (beside the OK button) until System Configuration menu appears on panel.
4.Then press OK two times to clear the error condition,
5.then cancel two or three times to return to the top menu.
6. Then power off and back on, print a test page
If this does not help you then the printer need to be replaced you can call HP and talk to the Supervisor
Posted on Apr 26, 2011
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
MY HP PHOTOSMART D7100 IS HAVING A PROBLEM ERR 0XC18A0001 IS IT FIXABLE?
The error means
PrintHead Failure / Ink system Failure
Hardware error
Try removing the printhead (If removable) and clean the contacts on it, if it doesn't works there are no ways to fix this error
ADCSFXworks Printing Center <3
Nov 29, 2014 | HP PhotoSmart Office Equipment & Supplies
HP Photosmart B210a error message
Simple. Remove the ink and printhead. You can remove printhead by pulling gray latch up and sliding printhead up and out. Clean printhead gunk off using warm running water. Remove any ink gunk on the right side of printer if you see any. Turn printer off and on. See if problem went away. If it did, try putting the cleaned printhead inside printer again. If problem comes back, seems like the issue is with a bad printhead. Below are video instructions on cleaning head manually. The printheads are not same. B210 printhead is not the same with HP 6500, but instructions are same.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 07, 2017 | HP DeskJet F4280 All In One Printer InkJet
Blue ink won't print
The cyan print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 20, 2013 | HP Officejet Pro 8500 Wireless All-In-One...
Error 0x 19a0027
Hi Norman,
The Error message usually relates to Printer Failure. However you can try few steps to fix it. ( Hopefully )
Turn off the Printer.
1. Open the Carriage access door.
2. Remove the Cartridges and Printhead ( Printhead is the part on which you install the cartridges )
3. Lift the latch to remove the Printhead.
4. Move the carriage from left to right 6 times and it should move freely
5. Clean the contacts on the printhead with lint free cloth. ( Golden dots at back of Printhead )
6. Turn on the printer and it should say " Printhead missing or not installed/Damaged "
7. Install the Printhead and Cartridges and close the latch and close the Carriage door
8. the printer should go through alignment process
If this step does not fix, You may try calling HP customer support to check for better options/solutions
HP Customer Care : 1-800-474-6836
Regards,
Sean
Feb 10, 2013 | HP PhotoSmart Office Equipment & Supplies
HP 6500 ALL IN ONE DISPLAYS ERROR ON SWITCH ON Ox61011BED
Hi Norman,
Regards,
Sean
Jan 29, 2013 | HP OfficeJet Office Equipment & Supplies
After print heads alignment its getting error 1004
The trailing cable is probably runing the printhead. Try replacing the printhead and trailing cable together. Parts available at: http://www.lpscomputer.com/c-622-designjet-5000-5500.aspx
Oct 13, 2009 | HP DesignJet 5500PS InkJet Printer
Alignment failure
Thanks, PREM
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Photosmart d5460 Printer "Ink System Failure 0xc19a0023"
you need to reset your printer. Do this: start>control panel>performance and maintenance> administrative tools> services: then scroll down until you come to print spooler, click on it and then in the left hand corner click on restart.
I do this whenever my printer gives me trouble, really works
Mar 11, 2009 | HP Photosmart 3310 Printer
I have just re-started my Canon PIXMA MP610 after it has been in storage for 2 months. It is around 1yr old. It seemed to work OK. When i went to print the 1st page, the paper jammed because of some...
I would suggest removing the printhead, make sure there are no more dead roach's under the printhead, also make sure all lights on the ink tanks are lite up, the first error code you mentioned has to do with the ink tanks, the second one has to do with the printhead. I would suggest un-installing the printhead, then reinstalling it doing the alignment, and that should clear the error code.
Sep 28, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Open Questions:
HP Business Inkjet 3000 Printer Logo
391 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
