Need value of resistors R7A4 and R753 in a Gateway VX700 monitor. Chassis family V8705. Board bears the codes CT920A2600 and CT920A2600. The resistors are physically located around the high tension transformer an have burnt to little crispies.
Long time since i worked on one of those chassis but if i remember right there both 250k ohm 1/2 Watt carbon in series
but its more common for them to go open circuit if there burned you better check out the rest of the circuit around the LOPT stage
Posted on Mar 03, 2008
WHAT IS THE VALUE OF RESISTOR R10 IN THE CIRCUIT BOARD?
Look at the color bands, they will determine the value. Last band color is the precision value of the resistor. You can find the color band values on many websites. The size of it tells you the wattage raring.
Mar 02, 2015 | Compaq CV 7500 17" CRT Monitor
I have a Westinghouse LCM 19v7 monitor that stays on for a few seconds and picture goes off. I know about the capasitor replacement but there is another conponent that I need to replace. It is the pow
That is the correct value. That resistor just gets very hot and discolors the PC board around where it is soldered. You should be able to remove all of the old solder and scrape the resistor leg to get it bright, resolder the leg to the copper pad and you should be good to go.
Oct 09, 2012 | Westinghouse LCM-19v1 Monitor
I have two crack green resistors colors are red, brown silver gold. what value is this. Its on the power board of a 24 dell monitor
The value = 0.21 ohms 5% tolerance
Use this WEB site to work out the value of the resistor.
http://www.smpspowersupply.com/resistor/resistorcolorcode.html
This WEB site gives you the color code values for resistors.
http://www.google.com.au/images?hl=en&q=resistor+colour+code&um=1&ie=UTF-8&source=univ&sa=X&ei=YHRsTfSsK5C2vQPA353UBA&ved=0CCsQsAQ&biw=1024&bih=416
Mar 01, 2011 | Computers & Internet
Incorrect resistors on DP1X PWB?
Assuming this unit was never worked on and it was actually working properly before the IC's decided to take a vacation I would recommend leaving them alone as there may have been an engineering change after the service manual was printed.
Apr 15, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Kds vs-f14
There is usually an identical resistor somewhere else on the circuit board, so if you cannot read the colors of the burnt one, you can read the colors from an identical resistor on the same board. If you just replace the resistor, it will probably just burn out again or damage another component, you have to find the cause of the resistor burning out, most likely an electrolytic capacitor failing. Look for bloated or seeping capacitors and replace those as well. Also look for broken or burnt toroid coils.
Jul 15, 2008 | BenQ FP731 17" LCD Monitor
Burnt resistor
You have to check what could cause these resistors to be burnt. It might be because of caps or IC. Unfortunately, I don't have this type of circuit board. If you cannot find it, try with the same value of resistors that are placed close to these fault resisters.
Mar 16, 2008 | Computers & Internet
Too Bright P1130
Dell P1130 Service Manual r + g + b resistors measure on them and chassis -ground by have a black picture for getting the highest voltages if its looks like out of range look the manual and the resistors on there values that the ones and values you write about can be made of the only few carbon composite resistors witch can have get some drift over time over the tolerance. this kind of dark brown resistors are very sensitive for moisture and more, best is to soldering one leg of the resistor out and measure for compare on every resistor its resist or disconnect the crt print from the tube and if the resistors are good then reduce on the potential meter on the line transformer some reduce brightness below if its so bright that its against the backlashes. control focusing also after that . i have only suggest by this chassis its a 25 years ago i was very busy with c r t t v and video and more a little study on the manual can give you other results for some deformed capacitors also why its come out of range begin with the power supply and don,t forget to disconnect before measuring the power supply the horizontal line load to the line transistor (fly back because of your multi meter and have a 100 w lamp in serial in mains to control for your power supply on .
Jun 17, 2017 | Dell P1130 21" CRT Monitor
Resistance value
plz send model number of monitor
Mar 09, 2008 | ViewSonic E55 15" CRT Monitor
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
