JVC PCW300 Audio system problem
Both the tape decks not working, radio not working, right speaker channel not working
    Genius:
  • 1,175 Answers
Power supply broken
youre looking at $100 or so to fix
Posted on Feb 28, 2008
I have a jvc kdg431 radio/disc player. recently the speakers stopped working intermittently. They have now stopped alltogether. Ihave looked at the fuse on the back of the unit & that is ok .
I have had this problem before. The first thing you have to do is fade the deck all the way to the rear. Now turn the deck off and than back on see if you have sound now? IF not fade the deck all the way to the front and turn the deck off and than back on see if you have sound now? What you are doing is checking for a bad speaker because if you have a grounded speaker it will shut off the decks internal amp. You can do this though out the left and right as well to find if is a that. Now if nothing you do helps you might have to replace the deck. IF you want to get carried away you can check the OHM,s on each speaker and check each speaker to a ground with an OHM meter and if you have any speaker that shows a speaker lead that shows a ground start chasing that wire and see if it has a screw through it. Go all the way to the speaker. You will probably find a bad speaker that has shut off you system ?
Jan 01, 2015 | JVC Car Audio & Video
I have a JVC KD-95 Cassette Deck. My left speaker Comes and goes lots of crackling. When I turn off the deck it crackles loudly then fades. my speakers work fine when using cd, radio etc.
Probably it's the playing head; must be damaged or worned out.. Accept fact; cassette players are outdated. make a listing of your favorite music and stat finding them on line.
By the way, even youtube rips are better quallity then thos cassette recors.
Aug 23, 2011 | JVC TD-W118 Single Cassette Deck
I would like to use my jvc home theater while watching tv. But i have no idea how or what wires to use to make this work.
You will need a 2RCA to 2RCA audio cable as shown below. Connect the audio out socket of your TV to the Aux or TV/SAT input of the JVC. When you want to hear the TV sound through the JVC system just select the appropriate input on the JVC. If you want the surround speakers to work, select ProLogic or All channel stereo on the JVC's surround settings.Because by default the radio or TV sound is only stereo, so only the front left and right speakers will work. PLII will convert 2 channel to 5.1.
Apr 26, 2011 | Audio Players & Recorders
Im changing factory radio to jvc and cut wires which ones are power source
here is a wiring color break down.
1987 Lincoln Mark VII Car Radio Wire Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Pink/Blue
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Blue/Orange
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
please rate my help.
Jul 26, 2009 | 1987 Lincoln Mark VII
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 03, 2009 | JVC KW-XC777 CD / Cassette Player
No sound coming from JVC Theater System when watching regular TV
  1. I am assuming that it has audio when using other inputs or tuner.
  2. Check that the TV inputs work by attaching a different input devise (cd player, Tape deck or vcr audio out) to the TV input.
  3. If you get audio the problem is with the TV audio out check that connection.
  4. Check the audio setting on the TV you may need to switch from internal speaker to external or from variable to fixed.
Good luck
Mar 07, 2009 | JVC TH-C50 System
Radio on my sony rx d7 hi fi 3 cd changer
check to maks sure you have an fm antenna connected
Dec 19, 2008 | Audio Players & Recorders
Faulty speakers or deck
the speakers are probably grounding out somehow, check the connections or for rust, my door speakers were rusty and grounded out, i just wrapped some electrical tape around the parts that touched the doors and i havent had any problems since, good luck, i went 6 months befoe i figured it out, i hope tis helps
Jan 16, 2008 | JVC KD-G720 CD Player
7.1 Reciever vs 5.1 Speakers
Are you gonna miss audio, well that is up to you, this is individual. 7.1 has two additional speakers - center left & right. My personal opinion is that it matters when you have your system installed in large space. Or you can by another two speakers an ad it. Good luck
Oct 08, 2007 | Audio Players & Recorders
Cassette player works fine, then screeches after 20-30 minutes.
Yeppers very common problem .. If the noise dosent come from the speakers then the problem is in the motor in the cassette deck. if the problem comes from the speakers when the deck is playing a tape, then the problem is in the record/playback switch. you may beable to fix it by spraying just a lttle bit of tuner cleaner inside the switch. It shouldnt cost much to have a repair shop do this as if you spray too much your going to ruin the belts and the mechanism. Good Luck
Jul 31, 2006 | JVC UXN1 Shelf System
187 people viewed this question
 Grubhead
Grubhead
