Kenmore has loose drum
Kenmore model 92590100. The drum is loose and takes up to three spins to empty drum
  • 156 Answers
Drum lose need more on that drum should move side to side all around if its not draining something blocking the pump if drum is lose its the basket drive block busted
Posted on Feb 29, 2008
My washer makes loud noise when spin. Does anyone know what could cause this? Kenmore Stack Washer/Drier Model #110.88752796
There are usually cement balance weights on the bottom of the drum mechanism. One could have come loose, and/or the drum is hitting the support posts in the case.
Nov 03, 2017 | Kenmore Washing Machines
Kenmore 500 bangs when spinning
Sounds like the bearing in the drum has bust but shouldnt be too expensive to replace.
Nov 19, 2013 | Kenmore 24902 Top Load Washer
My Kenmore front loader (model 417.40042990) makes a slapping noise at he start of the spin cycle and the tub is completely out of balance during the spin cycle. I tried the spin cycle with the machine...
open the door and turn the drum by hand push and pull the drum you may find that the bolt holding the drum in place has come loose you need to take off the rear panel to access the nut or bolt eric
Dec 27, 2017 | Kenmore Washing Machines
Kenmore series 80 dryer . Drum does not spin, even when empty.
Good day,
If runs and heats, then the most probable cause is a broken belt.
Not hard to change. Below is a tutorial on how.
The Kenmore line is manufactured by Whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Thank you for using FixYa
Dec 19, 2009 | Kenmore Dryers
Doesn't agitate or spin. Motor runs
model number not found. If it is a direst drive model you need to see www.youtube.com/watch?v=WLPGs2UMUJc
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Out of balance condition
I had a Fridadaire model and had the same problem. It could be 3 things. 1- the weight came loose that balances the drum. 2- the bracket that is attached to the drum could have cracked. 3. the bearings to the drum have worn out. All of these problems involve taking the washer completely apart. This is big process, but if you have time and patience it worth it.
Is this model belt driven?
Jun 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Nov 02, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore 90 series noise after spin
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Washing Machines Logo
509 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
