Question about Acer AL1703 17" LCD Monitor
Out of range
When using ms-dos or bios the monitor is working out of range, but in windows Xp working OK
  • Anonymous Jul 14, 2008
    same probelm
  • sanj_hoog458 Dec 25, 2008
    I have a PC with XP operating system and acer 16" LCD monitor. when run any dos base program or ms-dos on full screen then error massege "input not supported" appeared on the screen but with out dos based program was run properly.
    so please help me for solve theis problem..
  • 55 Answers
This is normal for a lot of newer monitors as they do not support those low resolutions.
Posted on Mar 14, 2008
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
Have Dell D266x gives me dell page that says bios revision and wont kick into windows
Visit the Dell Drivers Downloads websites and download the lastest BIOS version for the notebook.
See if you can get an MS-DOS version. Boot the system using an MS-DOS repair disk. then attach the disk with the BIOS setup by USB.
If you don't see an MS-DOS version, you may have to format and install or do a fresh install of your operating system (or a lower version that supported the BIOS). As soon as windows is re-installed, run the windows version you downloaded from the source disk you saved it.
This should work!
Apr 03, 2010 | Dell Latitude CPI-D Notebook
How do u find the ms dos drive
That's because ms dos isn't supported in windows xp
Check out this site for dosbox, a dos emulator
http://www.dosbox.com/
This program should allow you to run all your old dos games
even has support for windows Vista
Nov 02, 2009 | HP Compaq 6510b Notebook PC
Hi guys, I have a 21'' monitor running on an XP machine that was from a DOS machine. It was used on the DOS machine to run a specific program in a resolution using a little program called tmode that only...
- reboot pc
- while rebooting press F8
- choose safe mode
- choose administrator account
- go to control panel
- switch control panel to classic view
- click System
- click Hardware tab
- click Device Manager
- unistall "Monitor"
- then reboot pc
- wait til pc goes to windows
- windows will automatically install new Display Monitor.
Hope this help
Jul 14, 2009 | Computers & Internet
Want to install xp by caldera dr dos
The problem is hard enough for beginners . First :
1.DR DOS is used by ASUS . DR DOS isn't MS-DOS (Microsoft), just 99% compatible with it . You have access with it on whole HDD+cd/dvd but , because drdos will enable only 8MB RAM you can't install winnt.exe from i386 . There are at least 2 solutions :
a. if drdos is enable because u reseted BIOS try to change bios according to a better result (avoiding Caldera) and start a nice windows installation;
b. u may use another desktop/laptop until the first restart (in installation) ; u must try to use a computer with ~motherboard for best results.
Don't forget that DR DOS Caldera is almost every time used on ASUS MBs with all on board and you must have a PS2 keyboard/mouse to use any kind of DOS . I read sometimes that DRDOS is a soft used by Microsoft which it's wrong - there isn't any link between drdos and any windows system , genuine or not .
DRDOS problem might appear because it's a soft put on ASUS MB cd driver and , sometime, might be on a BIOS ROM .When u will boot with the MB cd driver in this kind of problem might occur .
Other way Caldera may appear is when u have a windows cd made careless with NERO and caldera will appear no matter the MB .
Mar 24, 2009 | Microsoft Windows XP Professional SP2
Clear BIOS settings
Flashing BIOS via software
If you have access to the computer when it's turned on, you could try one of those programs that remove the password from the BIOS, by invalidating its memory. However, it might happen you don't have one of those programs when you have access to the computer, so you'd better learn how to do manually what they do. You can reset the BIOS to its default values using the MS-DOS tool DEBUG (type DEBUG at the command prompt. You'd better do it in pure MS-DOS mode, not from a MS-DOS shell window in Windows). Once you are in the debug environment enter the following commands:
AMI/AWARD BIOS
Code: O 70 17
O 71 17
Quit PHOENIX BIOS
Code: O 70 FF
O 71 17
Quit GENERIC
Invalidates CMOS RAM.
Should work on all AT motherboards
(XT motherboards don't have CMOS)
Code: O 70 2E
O 71 FF
Quit
Note that the first letter is a "O" not the number "0". The numbers which follow are two bytes in hex format.
Jul 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
MS-Dos prompt in Windows 2000 & Xp
u can just press alt + enter when u r running ms dos prompt in xp or 2000, it will show u full screen and u once again press alt + enter it will back to normal mode when u come out u just type exit from the command prompt
Mar 16, 2008 | Computers & Internet
My AL1716 doesn not work in DOS
Hi
The screen probably does work in DOS but the laptop doesn't bother sending it any signal in DOS, it's only when windows starts that windows takes control of the displays and shoots out a signal to the external monitor
I don't know how you would get round this because you can't see your BIOS which you need to go in to and set the primary monitor to external.
Feb 06, 2008 | Acer AL1716 17" LCD Monitor
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Acer AL1703 17" LCD Monitor Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
