Question about Samsung SMH7174BC Microwave Oven
Samsung Microwave While the Microwave was cold ( first use of the day ), I was in the process of pushing buttons without any apparent problems, and then everything just went black, as if it was suddenly starved of power, totally black display. No blown fuses in the basement, and everything else on the same circuit appears to be working fine. Any ideas?
  • 2,130 Answers
You may have a blown internal fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 28, 2008
How do I access & fix the control board buttons (ie Hi/Lo/Off light & Vent) which some how got pushed in?
Thanks Michael but the problem is the light & vent buttons got pushed in so far that I can't use the fan or light. Please help!!!!
/uploads/images/access-amp-amp-fix-control-board-34894445-1-1.jpg
Jan 21, 2015 | Samsung 2.0 cu ft Over-the-Range Microwave...
Sharp carousel door often won't open when I push the door release button in.
Take the cover off end take a look how the hinges are mounted on it, If they are bolted on they can be readjusted, He man, Use your brain .
Oct 21, 2012 | Sharp Carousel Microwave Ovens
We have a Samsung MT1044WB/BB/CB. It is a Toast & Bake Microwave Oven. We have never used any function except the microwave oven over the 8-10 years since we bought it new. We have not used it in...
The computer died. Not much you can do with it. After ten years it doesn't owe you anything.
Of course you could bypass the whole timer with a toggle switch if you were MacGyver.
Apr 10, 2017 | Samsung MT1044 1000 Watts Convection /...
None of the push buttons work when i shut door light stays on can't reset anything
Try unplugging from the AC outlet for at least two mins, then try the unit again. If problem still exists after doing a cold restart then you may have a control board failure.
Nov 10, 2010 | Samsung MD800SC Microwave Oven
The door sticks and will not open automatically when you push the button to open the door - you have to manually open the door.
Clean the door swith housings and re align the door.
That should do it, any other problems will become apparent when you examine the door switch holders.
Nov 03, 2010 | Amana AMC4080 800 Watts Microwave Oven
My samsung MW5592W Microwave will not heat
My microwave is samsung MW5592W. I don't know what button should i use to set the clock. the clock button it just blink when I push it then I don't know other buttonS to use with it. I need help.
Sep 07, 2010 | Samsung Microwave Ovens
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
Switching off the sound of my Samsung Microwave
1 Press the Sound button. The display shows "ON".
("START" will flash)
2 Press the Sound button to turn the volume off. The display shows:
"OFF".("START" will flash)
3 Press Start. The display returns to the time of day.
Lastly, you can find a copy of the manual here:
http://downloadcenter.samsung.com/content/UM/200507/20050727140356453_DE68-01945A[GB].pdf
Sep 01, 2009 | Samsung MW1030WA Microwave Oven
Microwave Ovens Logo
143 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
