Question about Canon PIXMA iP1500 InkJet Photo Printer
Printer my printer does not function normally after i print one of my friend assignment. when i try another job printing, the ink was not clear and blur. i had try the maintenance and it still the same.. my printer model is IP Pixma 1000 canon please help me...
    Master:
  • 377 Answers
Have you try to make an ink replacement?
Posted on Feb 28, 2008
Printing problems, have cleaned, alighn etc, but printing is still blurred
If the printing is blurred it might need even more cleaning cycles to clear the nozzles. (I'm guessing it's an inkjet?) Or, there might actually be some cruft stuck to the side of the print head itself that's interfering with the ink pattern. You could try blowing some canned air through the printer. Another good thing is search youtube for your <printer model> cleaning. There's going to be at least one repair tech working on your printer showing you extra steps on how to clear things up.
Mar 13, 2015 | Office Equipment & Supplies
Copy result is blurred
Does the printer scan OK?
Is the platen glass clean?
Dec 10, 2013 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
I sent a print job to the printer and it started to print and just stopped. The ink, paper, & power source lights all began flashing simultaneously. There was no paper jam and the ink cartridges are...
make sure there is no pending print job in print spooler if it is there then clear it before giving the print .for clearing In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
Nov 21, 2009 | Epson Stylus 880 InkJet Color Printer
Does not print clear seems to run double image.
Do you use more than one computer with the printer and get same results? You may want to check with another PC, but either way you can try these steps easily:
Attempt to reset the printer, unplug it, leave it off (overnight would be best) but at least 15 minutes or so and try again.
Update Brother software and drivers on your computer, ensure computer software is working correctly, up-to-date, and has no errors.
Watch it print and ensure paper is moving normally as it prints, and that your paper type moves through the printer OK. If paper is sticking or hanging up as you print, it will blur/distort your print jobs. Clear out any debris or material making paper stick.
Oct 20, 2009 | Brother MFC 420CN All-In-One InkJet...
Canon MP145 Blur Printing
maybe u should check the printing setting/preferences, maybe it is set to general or normal... im not that familiar with the canon scanner.. i have an hp printer which is a scanner too, when i print pictures direct or from pc, i always check the settings before printing like setting to best resolution, setting to photo printing etc...
Sep 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
PRINTER PROBLEM where is my hp tool box? I HAVE INSTALLED NEW INK CARTRIDGES AND NOW MY PRINTER PRINTS OUT A LOAD OF PRINT I CANT UNDERSTAND. THANKYOU
Try double-clicking on the printer in the Printers and Faxes folder and clear any pending jobs. Turn off and disconnect the power cable from the printer for a few minutes to clear its buffer. Keep the paper removed from the tray during this process and only re-insert it after the printer has stopped attempting to print. When the spooler and buffer are cleared normal printing should resume.
Nov 11, 2008 | HP Deskjet 6940 InkJet Printer
Brother MFC-210c prints some lines blurred, letters stacked - alignment ok.
i have the same problem. repeated cleanings seem to help, when i print large fonts they come out pretty clear, but the smaller the font, the worse the blurring. 600 DPI prints mismatching patterns, but 1200 DPI prints perfectly fine. so i have found that printing on "fine" quality instead of "fast" or "normal" quality improves print quality ALOT. it uses more ink, but i am in business and need to be able to read very fine print!
May 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
51 people viewed this question
old marine
old marine
