Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
SONY GRAND WEGA KDF55WF655
TV POWERED OFF BY ITSELF, CONSTANTLY GETS BLINKING RED LIGHT, THE LIGHT BLINKS 10 TIMES, PAUSES AND STARTS AGAIN, OVER AND OVER, HELP?
  • 2 more comments
  • benrclark Mar 07, 2008
    Sony KDF-55WF655 Grand Wega is 3+ years old ...sceen goes blank and audio goes out for about 20 - 30 seconds and then comes back on. This occurs at random intervals - first it was happening maybe once a day and after a month or two it is happening about every 5 to 10 minutes. There are 3 indicator lights on the front panel; one for "power/standby"; the second for "lamp" and the third for "timer". The lamp light does NOT indicate (light up) to code a bad lamp. However, the power/stand by lamp, which is green when the TV is playing correctly, starts to blink continuously when the picture (and audio) disappear. Sony online help (chat) and tech support (phone) could NOT diagnos the problem and gave me the default/canned answer of "find an authorized repair service.
    I found an online blog that claimed this was due to a "weak" bulb, not one that was burnt out ... and simply replacing the bulb corrected the problem.
    Does anyone agree/disagree before I spend $200+ for a new bulb ?!
    Cheers !
  • vladoman Apr 07, 2008
    Same exact problem. Let me know if replacing the lamp worked please.
  • Anonymous Apr 18, 2008
    We have a 2 1/2 year old Sony Wega. Without warning the other night it went out, lights started to blink and after about 15 seconds went back on again for a few seconds, went out again, so on and so forth. Call to their help line was no help as I could hardly understand the tech as he had a deep accent. Their repairmen do not come out on the weekends. Recommended a local, who also does not come out on weekends. Wish we knew what it was so we could try to fix ourselves. Any ideas out there?
  • Anonymous Mar 24, 2014
    blinking red ligh
    t
Tv turned off black screen and red light flashes 6 times over and over again
Posted on Mar 07, 2008
  • fly1 Mar 07, 2008
    the flash count has no bearing on the problem?
I replaced the lamp ... it was the lamp. But while I was in there, I noticed a lot of dust had accumulated over the 3 years, so I vacuumed it out prior to replacing the lamp, so it could have been a thermal switching issue (overtemp). Regardless it works as good as new for $200 and no service call.
Posted on Mar 19, 2008
  • 108 Answers
I know this sounds silly but,
Is there a remote control with the standby button stuck down?
I get the flashing red light on the front on my Sony Wega when the remote gets stuffed down the side of the sofa but still manages to 'talk' to the TV set. This is due to some buttons being pressed, causing odd behaviour when the tv is on. when the tv is off the light on the front just blinks.
Posted on Mar 11, 2008
It's your lamp.. replace the lamp
Posted on Mar 06, 2008
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My KDF-42WE655 will not turn on . The green start up light comes on and I can barely see the tv come on . After a few seconds the red light starts blinking and does not stop. The screen never comes on ....
Hello! When was the last time you replace lamp in your TV? If long time ago (2+ years) - replace the lamp. If red light blinks in sequence (example 4 flashes, pause, 4 flushes, pause and so on) - then I need to know how many flushes between pauses. It is an error code. If it blinks just constantly - it is a bad lamp. Regards. Russ.
Apr 18, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony grand wega KDF55WF655 6 red blinks
you can try these steps if this doesn't work I suggest replacing IC8002 on the power supply
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks
Jan 24, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Sony KDF55WF655 TV ready green light blinks 30 times
Could be a bad lamp again. If this TV uses the XL2200 lamp, they are known for this intermittent behavior. If its not the lamp, a tech can access the self-diagnosis screen to see what's causing this failure.
michtech
Feb 18, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Wega
Please count light flashing again. Light flash time is "0.3 Sec" and there would be pause (light Off time) for "3 Sec". Start counting after pause to next pause.
May 31, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Kdf55wf655 55 inch sony wega 6 blinking lred lights
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
May 30, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
558 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
