1993 Clarion audio system for Saab 900. Tried to put the code in and it will not unlock. Keeps showing the code I tried to put in. I tried to clear it by pushing the band button in and holding it but to no avail. What can I do?
    Genius:
  • 1,175 Answers
Unplug ALL the power into the unit including the accessory power that runs the clock.
See if it works after you connect all back up.
Cant guarantee anything though.
Posted on Feb 28, 2008
HOW TO UNLOCK MY CLARION NX 710
I have the same problem, after disconnect battery connection my Mitsubishi outlander Navigation system Clarion NX710 locked.
I have translated the Japanese Clarion owners manual, it has a from to send with SD card, so they can reset it.
I have tried to open the SD card in a pc. but SD card just showed in a blink and disappeared, so can't open the SD card. if Clarion experts only need to work on SD card to unlock it, so why this SD card can't open and modify they PIN code stored inside?
Any one have any clue?
Dec 10, 2012 | Clarion NX500 Car Video Player
Changed the slave cylinder in my 1993 saab 900. Now have an airlock that I cant bleed out... now what?
I am not sure what all you have tried. I would continue to bleed the brakes starting at the left front and working around the car clockwise. when you change the slave it will take many many many times of doing this to bleed all the air out.
Nov 29, 2012 | 1993 Saab 900
Trying to get the radio code for 1997 Saab 900 Radio SN: AX2PU9716A PU 9716A Please assist me.
Your radio is made by CLARION and the only CLARION codeavailable for free (using a serial number ) from anywhere on the Internet is ifyour radio also has a BARCODE SERIALNUMBER beginning with C 7000000 + + ++ on a label somewhere on the metalcasing. If not then it will only be available from your Main Dealer or a Decoding Service oryour local Car Radio / Audio Store who will connect a laptop to read/recode thememory chip (EEPROM) inside your radio
Apr 07, 2011 | Car Audio & Video
I NEED TO GET THE UNLOCK CODE TO MY 1992 SAAB 900 TURBO CLARION RADIO.
take it to the dealer with proof you own the car
Oct 20, 2010 | 1992 Saab 900
Unlock radio code
Assuming that you have the original Clarion radio, the code should have been provided by the original owner. If not, you might be able to get it from a Saab dealer by way of the VIN lookup.
Assuming you have the correct code (of four digits I believe), the entry drill is as follows:
  1. turn on the ignition,
  2. depress the radio power switch once,
  3. depress the DNR switch and keep it depressed throughout the rest of the procedure,
  4. key in your code number using the station preset keys (1 through 6)
  5. after last digit is entered, release the DNR switch and unit should operate
If you make an error entering the digits, simply release the DNT switch re-press it and start entering the digits from the beginning.
Dec 21, 2009 | 1991 Saab 900
1992 SAAB 900. Clarion radio. After repairs to
Are you sure that 1112 is the correct code as it looks as though your radio is not accepting it.
To check, post the radio MODEL NUMBER (begins with PU ) and also ALL the LETTERS+NUMBERS on any labels, barcodes or stamped in the casing and I will be able to see if I can check the code.
Sep 11, 2009 | Car Audio & Video
Radio code
It is the wrong code or the wrong entry  instruction
CLARION code entry instructions can be found here
Select your model from this long list
http://www.radio-code.co.uk/code-entry-help-Clarion.htm
Jun 27, 2009 | 1998 Saab 900
Entering radio code
Mar 01, 2009 | 1994 Saab 900
1993 SAAB CSE LOCKED STEREO
If this stereo is a clarion and original equipment and uses a a four digit code. First thing you do is with the power on to the radio, push and hold the band button for a few seconds until you see the word "code" on the radio display. Input the code and radio should work. If that doesn't work, then if you have tried to input a wrong code several times then radio will lock out. So what you need to do is
the radio has to be on for one hour uninterrupted, then you can do the band button procedure , code input again and hopefully the radio goes on. Hopefully this helps. Please advise results
Feb 21, 2009 | 1993 Saab 9000 Hatchback
Clarion cd changer for saab 900 s
I have a Clarion CD changer for sale.
Call 630-842-0888
Sep 27, 2008 | 1997 Saab 900
43 people viewed this question
 Grubhead
Grubhead
