The passenger headlight has burned out. What are the proper steps to replace the bulb, starting with how do you properly remove cover to change passenger headlight bulb?
The directions for changing the headlight light bulb in all cars are near to same . but all car models are not the exact same, so there may be a few differences based on your particular car. But this.instructions may properly guide you about the directions to replace the head light bulb in your car.
The instructions are as follows :----
1) First of all open the hood of your car and put a spot light or flash light onto the back of the headlight. Look towards the far corner side of the hood, the headlight is located in a space mounted to the far sides.
2) In some of the car models there is a back cover for which you will require a screwdriver to unscrew the back plate to reach to the bulb. properly locate the screws and unscrew the screws using the proper size screwdriver.
3) Then remove the back plate.
Note: In some car models there will be a wiring component connected usually by plastic clips, so detach the plastic clips and then pull wiring to the side. Then remove the back plate.
1) Remove the Old Light bulb which will be easily visible. Then remove old light bulb by screwing it to the left slowly and carefully.
2) You can get the new light bulb from local auto store and purchase the bulb exactly that matches the one your car model .
3) Then insert the new light bulb in reverse by screwing to the right, and secure in place confirm bulb is properly connected and fitted and not remained loose.
4) To test whether the bulb is properly connected. Just try turning on headlights and make sure it lights up.
5) Then plug wiring component back in if your model has that.Then put backplate back in place , then insert the screws back in and screw in with screw driver tightly.
6) Then close the hood properly and check out head light again.it will work properly.
That means your work is done.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Whether they become damaged in an accident or simply burn out over time, your Subaru Outback's headlights may eventually need to be replaced. Fortunately, once you've purchased the right replacement bulb for your model year, performing the repair yourself is relatively easy. These instructions only apply to Outback models made after 2000.
Undo the clips on the air intake ducts using a screwdriver and remove the duct from the engine compartment (driver's side bulb removal only.)
Loosen the secured clip on the washer tank with a screwdriver and slide the tank horizontally to allow easier access to the headlight assembly (passenger's side bulb removal only.)
Turn the bulb cover counterclockwise and remove it from the assembly.
Disconnect the headlight electrical connector and undo the assembly retaining spring.
Pull the old bulb directly out of the socket and replace it with the new one. Press the retaining spring back into place and reattach the electrical connector.
Replace the bulb cover, and then turn on the engine. Test the new headlight to make sure it works before replacing the air intake duct or the washer tank and closing the hood.
Undo the clips on the air intake ducts using a screwdriver and remove the duct from the engine compartment ( drivers side bulb removal only.)
Turn the headlight bulb counterclockwise and pull it out of the socket.
Reinstall the new bulb, replace the retaining spring and reconnect the electrical connector.
When a headlight burns out on your Chrysler
Crossfire, you do not need to rush to the repair shop to have it
replaced. You can access the headlights in your Crossfire from within
the engine compartment, allowing you to change the headlight yourself.
The Crossfire uses an H7U headlight bulb, which you can find at auto
parts retail stores or at a Chrysler dealership.
Difficulty: Easy
I need to replace amber bulb inside cover of headlight l. procedure?
