Question about Dryers
Indesit is70c dryer is not heating?
I have an Indesit is70c dryer, it was working fine up to last night we put a load into it, cleaned the filters and emptied the water tray as it is the condenser model but after the full time the clothes are still wet. the drum is turning fine with motor ect... but its only blowing cold air is there a thermal fuse or switch on or inside machine or is the heater element gone???
Ian
Co. Down
  • k8119098 Jun 14, 2008
    i have an Indesit is70c dryer, the drum is turning fine with motor ect... but its only blowing cold air is there a thermal fuse or switch on or inside machine or is the heater element gone???
  • Anonymous May 13, 2009
    i have same problem
Take off the back plate of the drier to expose heating elements. There you will find two thermo switches, one with a hole in the middle of it. Push something like a pin into this hole until you hear a click. Re assemble back plate and it should work now
Posted on Aug 31, 2009
  • Margaret gregory May 05, 2016
    Where exactly is this hole I have the same problem but can't find the hole to put pin in there is 2 panels a small half moon shape and a large with a wheel to turn drum can u tell me wat 1 it is please
- JUST TRIED THIS, WORKED FIRST TIME, IF I DIDNT SEE THIS I WAS GOING TO HAVE TO BUY A £50 HEATER ELEMENT AND £17.99 THERMOSTATS!.. THANKS SO MUCH WE HAVE SAVED £67.99 REALLY CAN'T THANK YOU ENOUGH (ianmann288). Cheers! A credit to fixya!
Posted on Nov 19, 2009
  • 5 more comments
  • joebhoy67 Sep 23, 2010
    Fantastic, thought I was going to have to buy a new tumble drier, worked a treat. Nice one!!!!!
  • stevemarc832 Feb 04, 2011
    That worked brilliantly thanks a lot you saved me from buying another one!!
  • liammolloy Aug 10, 2011
    got same problem but my thermostats dont have a hole in how can you tell if they have blown or if the heating element has gone
    cheers
    liam
  • Anthony Moore
    Anthony Moore Oct 20, 2013
    Take the two screws off the metal back plate that holds the plastic housing containing the thermostates. Remove housing. The hole is on the reverse side of one of the thermostats. Push a pin in it to reset (you will hear it click). Re-assemble all parts and the dryer heats up nicely.
  • Anthony Moore
    Opps spelt thermostats incorrectly.
  • Beverley Docherty
    Beverley Docherty Jan 08, 2014
    I've just tried this and it worked. Thanks so much for your help , probably saved me a fortune and definitely saved me some ironing!
  • James Campbell
    James Campbell Jun 29, 2018
    Just tried this fix and it worked for me too! Very pleased indeed with the expert tip.
Must be Groundhog Day .. my IS70C has done the exact same ie: started a burning smell then stopped heating - a jammed bra wire didn't help.
I took the small cover off then the cover over the heater/motor - the two thermostats are located above the heater but you have to take the 2 screws out to release the heater element to get to the back of the thermostats. I used a drawing pin to reset it and it worked immediately.
I thank you very much for your help in this matter!
Paul
Posted on Nov 20, 2009
  • 6 more comments
  • rocketeer Nov 13, 2011
    Brilliant, this worked for me a treat. Thanks a lot for sharing!
  • DHolland1 Apr 21, 2012
    Superb! Works perfectly. In a week where a woman reversed into me, cat fell ill and hubby away working, was last thing I needed to go wrong. Thank you. :-)
  • tj1934
    tj1934 Jan 01, 2013
    fantastic bit of advise worked a treat thank you very much
  • stu wade Apr 28, 2013
    brilliant, sorted it in 5 minutes.. thanks for the advice
  • lee Johnson Sep 29, 2013
    beauty thx this worked 1st time
  • angelica dawn
    angelica dawn Feb 14, 2014
    thanks, tried it and have now seen i actually need to throw my dryer out. there are some blue & red wires that look like they lead into some kind of spiral coil for heating... well the whole thing was burned out inside!!! i doubt i can fix this on my own so it may be jbest to invest in a new dryer. but thank you that tip was still helpful!!!
  • Martin Douglas
    Martin Douglas May 23, 2017
    Thank you so much. I removed the back cover expecting to find a button. I would never have thought that's where the button was. Much appreciated.
  • Angela Greenlees
    Angela Greenlees Jun 03, 2017
    Has anyone got pic where the thermos switches are please
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Posted on Jan 10, 2010
Thank you! that worked.
Posted on Nov 15, 2014
I have an Indesit is70c dryer, the drum is turning fine with motor ect... but its only blowing cold air is there a thermal fuse or switch on or inside machine or is the heater element gone???
Posted on Jan 13, 2011
I have Indesit IS70C dryer and all of a sudden it's not getting hot when switched on and the water container is empty..water is not draining from the clothes to the container and machine is not getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.//.';';]\\
Jul 25, 2011 | Indesit IS70C Electric Dryer
Hi I have an Indesit is70c dryer it seems to work fine for 10-15 mins but then trips the fues box in the house as it cuts out. I've had a look for at the fuse and have cleaned out all filters / condensers....
Do not overload the dryer as the motor can struggle and try to draw to much power.which could cause the trip to go to out, only load drum half full.....this applies to washing machines as well"NEVER OVERLOAD THEM" with washing machines it can affect the quality of your wash as well as putting extra strain on the motor.
Nov 08, 2017 | Indesit IS70C Electric Dryer
Indesit condensor tumble dryer does not heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 08, 2011 | Indesit IS70C Electric Dryer
Reset on indesit dryers not heating
heatman101
Nov 01, 2010 | Indesit IS70C Electric Dryer
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
Hi,my indesit IS70C tumble drier works but does not heat up.\possible causes please.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Indesit IS70C Electric Dryer
How can i fix my indesit is70c tumble dryer? my indesit is70c tumble dryer wont heat up during performance
open the back panel , not the the full back just the smaller panel located near the bottom half.
the termo will be screwed onto this panel . unscrew and you will see two circles near the top one will have a small pin hole in it . stick a pin in till you hear a click replace and should work fine
Mar 05, 2010 | Dryers
Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
Common faults -
Feb 24, 2008 | Dryers
Dryers Logo
8,562 people viewed this question
Top Dryers Experts
Marvin
Marvin
