Question about Brother MFC 240C All-In-One InkJet Printer
Unnable to make the connection
Suddenly my printer was giving 'unable to connect' messages. I checked all connections, restarted the computer and printer several times and reloaded the printer software. Now, to install the machine, I am being asked to: choose the Brother machine I want to install. It will not allow me to put in the machine name on this screen unless I select "custom" to install the machine manually. This screen will not accept any information I put in. HELP!  And thank you!
  • Anonymous Apr 17, 2008
    every time the usb cable is unplugged we have to reinstall the software, now we cant find our disk to install it. I need to find out why we have to reinstall it and find out how to get the software disk.
  • 832 Answers
Do run the aggressive (usb) driver remover which is part of the install cd. or download from brother home page. read instruction when and how to use this little program.
Posted on Feb 29, 2008
    Problem Solver:
  • 5 Answers
WHEN YOU FIRST INSTALED THE SOFTWARE THE DRIVERS FOR THE USB WERE SAVED IN C:/WINDOWS/SYSTEM32
WHEN ASKED FOR DRIVER BROWSE TO THAT DIRECTORY AND THE DRIVERS WILL BE INSTALLED.
Posted on Jun 19, 2008
Print unable EF
turn off the printer then refresh th computer that the prinyer is connected to then turn the printer again and restart the computer thgat shald do it.
Jun 17, 2013 | Office Equipment & Supplies
I have a canon pixma mp 287 printer i have installed the drivers also and it is also not offline but when i am giving command to it then it is showing that printer is not responding.why it is showing like...
solution :
1. Uninstall driver printer and remove Printer USB cable from computer. After uninstall finish, restart printer.
2. Reinstall driver printer (don't connect printer USB cable to computer). Wait for the install process, until message "connect a printer USB cable to computer". After message appear, connect printer USB cable to computer.
3. Wait process install finish and try to print.
Sep 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Ihave a dellp513w and some how i put the disc in that came with it trying to get it connected to the computer so i'am able to print from the computetr and it want work. The disc want connect to the...
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Uninstall the printer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
With your computer online, Insert the printer disk or try using the drivers located at...
Dell P513w Wireless All-In-One Printer owners thread
You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block printer communications.
Rick
Apr 19, 2011 | Dell 948 All-In-One InkJet Printer
Unnable to access hdd
First thing to do is disconnect the camera from the computer and do a reboot of your computer. Once the computer has restarted, give it a few minutes to load up. Try re-connecting your Handycam to your computer and see if it recognizes it. You may want to try using a different USB port on your computer also.
Mar 01, 2011 | Sony Handycam® DCRSR45 HDD Camcorder
Printer unable to communicate with computer.
Are you using the wireless network printer function or is the printer connected by a USB cable? If you are using the wireless network, launch the printer's Wireless Setup Utility and run through it. (Check for problems with IP, signal strength etc.)
For USB, try resetting the printer (unplug it from the wall for 10 seconds). Check that the computer is looking for the printer on the correct port. Click Start > Settings > Control Panel. Double click on the Printers folder and right click on your Lexmark printer. Choose Properties then click on the Ports tab. Check that one of the USB port options is checked. (If you have a newer OS, Start > Devices and Printers and then right click on the printer.) Also try a new USB cable and a different USB port. If you have a print server or USB hub, try a direct connection.
I hope this helps.
Apr 22, 2010 | Lexmark X3350 All-In-One InkJet Printer
Suddenly, my hp printer won't print. I use
try to remove everything from printer that connect to you computer, from you pc remove driver restart and connect your printer it must be a pop up that found new hardware to you computer. in not then you computer not detect that printer. try to replace printer cable. if still not work tr to connect your printer to other computer to conclude where the problem. from printer or from you computer. please give feedback for next trouble shooting.
Apr 13, 2010 | HP PSC 1610 All-In-One InkJet Printer
Printer stopped working claiming the jobs have been 'stopped' and giving no explanation.
Hi Plug out the usb cable from the cpu. Try deleting the printers from the printers window(START, Printers and Faxes), uninstall the software. Power off the printer and unplug power adapter. After the printer has been deleted from the printer window, plug it back in and reconnect back to computer. Then try a new installation of the printer and software. The pending documents that have been stopped should now not be in the spooled documents.
May 02, 2007 | Epson Stylus DX4200 All-In-One InkJet...
Brother MFC 240C All-In-One InkJet Printer Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
