Question about HP (176135-630) (176135630) Internal 48x CD-ROM Drive
HP DVD WRITER 840b - CD/DVD Tray won't open??!!
I purchased my HP Pavilion a1325a computer in July 2006 and have had no problems with it, but just over a week ago I discovered the CD/DVD Disc Tray won't open??!! (aaarrgghh)
When I press the "Eject" button, it makes a whirring sound and sounds like its trying to push open, but then it fails to do so, and sounds like it pushes itself back into its original starting position.....
I'm picking the actual mechanism that opens the tray is stuck or jammed, or something similar. The tray sounds like its trying to move but the cover just won't open.
I'd apprciate 'ANY' ideas at all, I just don't want the hassle of taking my towercase into the shop and being "out of action", so to speak. >LOL<
Thanks in advance
Liz in New Zealand :o)
  • 3 more comments
  • Anonymous Apr 03, 2008
    I have the same issue. After manually opening the drive, it work correctly for a little while, then it gets stuck again, and will not open by itself. still looking for an answer.
  • momat88 Apr 07, 2008
    Hi all, well I tried the paperclip thing and nothing happened - so I ended up taking it in to be repaired (as it was still under a 5yr warranty) and they replaced it with an LG Super Multi Drive.
    Thanks for your posts, I hope y'all find solutions from someone in Cyberspace :)
    Ciao for now
  • Tennis4Fun Jul 16, 2008
    Yes I have the same problem too. I have managed to work around it by doing the following: First I have 2 DVD drives--I've found that by clicking start and clicking my computer--I highlight my other DVD drive right click and select eject and click it opens the second drive--I can then highlight the first DVD drive and right click and select eject and it opens the DVD....such that both drives are open but that is okay by me--because it works!
  • dilly98 Nov 28, 2008
  • shoo787 Mar 03, 2009
    I have a HPdvd 640v external writer and it wont play either a cd or dvd
I've had this problem with my HP drive for some time and have to use a paperclip to open it. However, I've just read Solution #4 and this works fine - just leave a CD in the tray all the time and it opens and closes as normal ! Thank you "Guest".
Posted on Sep 05, 2009
Problem of tray opening on hp dvd burner. I got the door open as suggested above with paperclip. Then took some CRC 2-26 plastic safe electrical grade lubricant and swabbed the pivoting door mechanism. Opened with the paperclip about 5-6 more times until it finally opens normally.
Posted on Nov 16, 2008
    New Friend:
  • 3 Answers
I have discovered the answer to this common problem (at least on my LVW-5006), it's to do with the little "turntable" which the disc sits on, it would have been made with a padded "ring" of felt or rubber etc. which was self adhesive and stuck onto the turntable, now if this ring comes unstuck you're just left with the adhesive which the disc and/or the weighted "press" above the disc will stick to (the latter when no disc is present). When you try to open the tray the mech tries to drop the whole laser/turntable assembly away from the disc to allow it out; but it's effectively "glued" to the upper assembly or the disc itself and that's when you hear the eject motor straining and squealing (and probably giving up!). Often a tap on the lid will free it but the best solution would be to replace the ring pad, although I suspect just removing the adhesive would work (I've noticed that cheap CD players don't even have such luxuries in the first place!) Hope this helps
Posted on Nov 29, 2014
I have this problem with 2 different dvd writers, one is an HP and the other is a TSSTcorp. Can't figure out the problem or even find an answer
Posted on Aug 21, 2008
I have this same problem with a HP 640b lightscribe DVD burner, I am searching for a solution but in the meantime have found a temporary solution...The drive works fine once I get it open and disc inserted, so right now I use a paper clip and manually open the drive through the pin hole slot on the front of drive (push paperclip into pin hole and drive will tray will come out as you push clip in, then you can manually pull drive tray out and insert dvd/cd), once a disc is in the tray my burner opens and closes fine, mine has a problem only when the disc tray is empty. The drive burns well even with this glitch. Will post again if I find a real resolution to issue.
Althea88, to lazy to find pswd so guest right now.
Posted on Mar 19, 2008
Omg i cant believe everyone has the same problem.. lol I have a a867c pavililion with a lightscribe dvd writter and the trait wont open :@ its getting me so pissed! but before it used to open by just turning the pc off and then back on.. now ill have to try the paperclip thingie.. please keep me informed if u find a solution!!
Posted on Aug 22, 2008
Do I need sata or eide for internal dvd writer on HP a1330n?
This model HP has a SATA disk controller.
You need a SATA DVD writer.
If you are not sure, when you remove the faulty DVD writer, take it with you when you go to purchase a nre DVD writer, make sure the new DVD writer has the same connectors as the faulty DVD writer.
Jan 22, 2012 | HP Pavilion Media Center a1330n - AMD...
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
I have an HP DVD+R/RW 16x10x32x4x2.4x8x Drive and i am trying to find the drivers for it to see if it works on my computer. I have tried typing up the Product Number and HP Part Number on the HP website,...
DVD-RW 16X HP DVD Writer 740b Drive Firmware Update ftp://ftp.hp.com/pub/softlib/software7/COL16063/pv-42566-1/sp26595.exe
you must be logged in as the computers administrator to install this update
or
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07165&cc=us&dlc=en&lc=en
Update your HP desktop computer to have the latest software and drivers available. HP provides many software and driver updates free of charge
hope this will help you
  • You must be logged on as an administrator to install this update.
  • HP DVD Writer 740b drive.
  • Blank floppy diskette, recordable CD (CD-R), or USB Thumb Drive.
  • Released: s.gif 2006-08-23 Version: s.gif HI24 Compatibility: s.gif Microsoft Windows XP
    Aug 21, 2011 | HP/5.25 16x10x32x4x2.4X8x IDE Carbon...
    Dvd writer & cd writer tray lights up but will not open on HP pavillion model no t760 uk
    Go into My Computer and right click your DVD writer/CD Drive and click eject.
    Mar 05, 2011 | HP Pavilion a1700n PC Desktop
    I am looking for a hp lightscribe dvd supermulti drive/cd writer that is compatable with a hp pavilion a720n desk top computer and all so a dvd/cd rom combo that is compatable with ...
    Any brand-new CD/DVD reader/writer with LightScribe *WILL* be compatible with your HP.
    Check whether your "power" and "data" cables are the "old" style (white power connector and a 80-pin ribbon-cable) or the "new" style (thin SATA cables), before you buy a writer with the "wrong" (PATA versus SATA) interface.
    Sep 26, 2010 | HP Pavilion A720N PC Desktop
    The cd writer/dvd tray on my hp pavilion 533w will not open. When I press the button to open the green light comes on and I can hear a whirring sound but then the light goes out and tray doesn't open....
    I understand you can't find that pin hole that's supposed to be there. but just to clarify it's supposed to be on the face of the cd/dvd, not the case. also, just trying to help, did you try opening it WHILE your pc was booting up? maybe try from windows explorer and right click on the drive from that window and try eject or open option.
    Sep 16, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
    When I put a cd r in my burner then press burn selection then it
    Try downloading a program called " RadarSync" it works like driver detective, might possibly help you out.
    www.radarsync.com/
    Dec 19, 2008 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
    HP 640b DVD Writer tray will not eject after burning DVD
    If all else fails you can take it to best buy
    I did that with one of my comp.
    Dec 17, 2008 | HP LightScribe dvd640i (DVD640I)...
    Can not get my cd dvd writer to open on my hp pavilion a810n
    If no lights shown on drive, Check if power conncetor is rightly & securely connected to drive. try with other connector.
    If still the problem persists, change the drive
    Jun 27, 2008 | Computers & Internet
    HP (176135-630) (176135630) Internal 48x CD-ROM Drive Logo
    7,235 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
