Question about Eureka 2961AVZ Bagless Upright Vacuum
Belts breaking frequently
I have the Eureka 2961 model. The belt broke recently and I replaced it according to the directions. Aflter I started the vacuum within 60 seconds the new belt broke also. Why is this happening?
  • Kauser Mar 17, 2008
    Thanks, I really wasn't wanting to have to buy a new roller. I tried the WD 40 thing and it really worked. Now it's working fine, great news!!!
  • Anonymous Mar 20, 2014
    Vacuum was running when belt broke, but after belt was changed, now when you plug it in it won't even turn on
I had the same problem. Broke 2 belts before I got online and noticed this site! What I found was, the roller ends were not turning freely. I had cleaned the hair (nasty) off the roller, but the ends were still not able to spin around without some force.
What I did was, removed the roller and on the 2 ends there are 2 black plastic caps which fit over the bearing, I removed the plastic caps and put a little WD-40 on the bearing, or any industrial lubricant, even new motor oil will work. After putting on the WD-40, I spun the roller end around a few times and the WD-40 lubricated the bearings and Voila! The roller end spun freely!! I put the black caps back onto the bearings on both sides, reinstalled a new belt, it's been working great since.
It saves the cost of a new roller.
Todd M, Fremont CA
Posted on Mar 15, 2008
    President:
  • 1,673 Answers
Did you check the brush roll, if not take it out, see if the ends are ok and turn freely, if not then replace it.
Posted on Feb 28, 2008
What Model replacement belt do I need for the Eureka model 2961 BVZ?
Greetings,
According to the Eureka Part diagram for your particular model vacuum, your vacuum uses Eureka Style U Belts. Eureka makes actually 2 different styles of U belts.
The first style is the standard U belt, Eureka part number 54312. This belt is probably the one that came standard on your model. You may purchase this belt from the link below;
http://eurekaservice.stores.yahoo.net/uprightbelt.html
The other type of Style U belt that will fit your model is the Eureka Extended Life Style U Belt, Part 61120B. The Extended U belt is more durable, and lasts longer then the Eureka Standard U belt. You may purchase the Extended U belt here;
http://eurekaservice.stores.yahoo.net/exlifubel.html
Now, if you are quite sure how to change your belt, you may visit the link below to see the owners manual for your Eureka 2961BVZ that will give you step by step instructions on how to change the belt;
http://eureka.com/service/manuals/80244.pdf
I really hope that this was helpful to you in finding and fixing the belt for your Eureka. If you did find this helpful, please be kind and rate my repair solution as helpful by clicking the thumbs up icon in the lower right hand corner below. I really do appreciate it, thank you.
Feel free to request a repair clarification if you have any questions about the procedure of installing the belt on your Eureka, I'll be happy to help.
Chris J.
Mar 12, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka bagless model 2961 partswere do i get them
It depends on the parts you are looking for. If you go to your local vacuum repair shop they might have parts for your model. If not then there are parts available on Eureka's website. If you need replacement belts for your model you can get them here:
Eureka 2961 Replacement belts
Nov 08, 2009 | Vacuums
What is the belt size for the Eureka model 2961 type bvz
The belt size for your particular model is belt
54312C
Worse case if you can't find this part at the store you can purchase directly from http://eureka.com/servlet/ListParts
Sep 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
What belt do I use for the Eureka Altima 2961?
Click this link and it will take you to Eureka's website. Just enter your model number and part description and it show you parts you can order for your model. There is also an owners guide you can download.
Hope this helps.
http://www.eureka.com/parts.jsp
Aug 21, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka 2961 BVZ no suction, burning smell
I have the same vacuum. The burning smell is letting you know that your belt is either broken or about to break. I have had mine for a year and have had to replace the belt 5 times. Now I have to replace the brush roller 'cause it broke under normal use. My next vacuum will be a Dyson Ball.
Jul 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Apr 15, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Smoking belt
Belt is slipping because the bearings on the beater brushes, which it turns, are jammed or full of dust.
Alternatively the belt has stretched after being overheated and needs replacing because it now slips.
Dec 22, 2007 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka 2961AVZ Bagless Upright Vacuum Logo
213 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
