Question about IBM Lexmark Z715 InkJet Printer
Paper jam I have a Lexmark Z715 printer and I had a paper jam. I got the paper out and now it won't print. I get messages like load paper. When I do the paper wont feed properly. Can you help? Connie
  • Anonymous May 05, 2008
    The paper is not loading into the printer. When I turn it on it makes a funny nouse and states that the printer is not responding.
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Mar 19, 2009
I have a Lexmark Z715 Printer. It has a paper jam I cannot clear - picked up about 15 sheets of paper at one time and I cannot get it unjammed. Is there a trick to solving this problem?
Some sheets are jammed more tightly than others. Check to locate and remove the less jammed sheets to make it easier to remove the rest. With some printers, it helps to "riffle" the supply first to prevent sticking. You also may have loaded the printer with more sheets than it can handle at one time.
Nov 01, 2013 | Lexmark Z715 InkJet Printer
I have a lexmark z715 printer connected to windows xp. recently it stopped printing. the paper moves and the machine makes sounds similar to printing, but it doesn't print. i think the sound is s
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 23, 2013 | Lexmark Z715 InkJet Printer
I have a Lexmark x2600 printer and when I stated printing many pieces went through and then jammed and won't move in either direction, the paper is really jammed in and I don't see any way to get...
Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
Tips: Use only paper that is in good condition. Fan the paper before loading into the feeder to prevent sticking together. Use the specified media type and sizes for your model. Don't overload the feeder.
Jul 24, 2011 | Lexmark X2600 InkJet Printer
Papaer jam "check duplex"
Here's an article in the Lexmark website on Paper Jams and the Printer Displays a 'Check Duplex' or a '23x' Type Paper Jam Message: Lexmark T650, T652, T654, or X65x Series Printers. Just click on this link: http://bit.ly/aqGjtK. Read the instructions thoroughly. Hope this helps but if you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 25, 2010 | Lexmark T652DTN MONO LASER PRINT Printer
How do i clear a paper jam
The Lexmark Printer you are having a very sensitive printer.
Normally this tyoe of Printers are very very slow in Printing job.
Comparing with other laserjet used.
If the Laptop / Printer are under warranrty, the Service engineer
can rectifity the printer jamming.
Solutins :
Make the Printer - Monthly service compulsory.
Use only good quality paper in the Lexmark Printer.
Do not pull the paper through hand, when the print out is coming.
Regards
Jul 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark z715 problem w/printing
Good luck...
Nov 10, 2008 | Lexmark Z715 InkJet Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark P4350
Solution:
I have a Lexmark and it says that there is "No Loaded Paper" some times and when you click ok it keeps saying it. If the power light is flashing on the printer - try this suggestion.
Suggestion:
  1. Press the power button (Which will turn off printer.)
  2. Wait till flashing stops and printer is completely off.
  3. Press the same button which will turn on the printer.
  4. The Printer should automatically go back to printing.
  5. If it does not - Manually try printing by your self.
Dec 04, 2007 | Lexmark P4350 All-In-One InkJet Printer
Dirty Cartriage or Printer head
you should clean the printer head or cartriage
Aug 31, 2007 | Lexmark Z715 InkJet Printer
IBM Lexmark Z715 InkJet Printer Logo
202 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
