Question about HP Pavilion dv1000 Notebook
Hp pavilion dv1000. All 3 USB ports not recognising any device
All USB drivers er OK in control panel/system/....
Every other parts except usb ports works all right.
Nothing seems to help. Not even formatting, reinstallation and automatic update from HP site helps
  • Babasala Mar 01, 2008
    I have updated the drivers from device manager and it didn't help.
    How do I solve the case of a loose connection with the motherboard? I suspect that must be the case.
    Thanks for your efforts
    babasala
  • 796 Answers
Go to device manager and from there try updating the usb drive from there
Posted on Feb 28, 2008
  • isaac johny
    isaac johny Feb 28, 2008
    if this also not works there must be some loose connection with the motherboard or usb port then
  • isaac johny
    isaac johny Mar 01, 2008
    he usb port has a set of wires connected to the pins on the motherboards......
    what you have to do is to trace the wire from the port and see if the ends are fixed on the motherboard or not....
Usb device not recognised when m audio profire is connected to hp 625
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Hope it helps.
Jan 28, 2013 | HEWLETT-PACKARD 625 Tur II P540 Notebook
I want to download usb port for pavilon dv6-6c40us
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 18, 2013 | HP Pavilion dv6-6c40us AMD Quad-Core...
USB not recognised
Go into your device manager by clicking Start/Control Panel and from there it depends on your operating system as to where the device manager is. In Windows XP they are under System\Hardware. Once you are in the device manager look for Universal Serial Bus Controllers and if you have a + next to it, click it to expand it. See if any item has a ? on it. If so right click on it and select Update Driver.
If all are ok, then maybe you need to try a different USB Port. If all ports act that way you might be experiencing a motherboard issue with the usb controller.
Are you ever getting a message such as "Your device could work faster if you plug it into a 2.0 usb port"? If so, that might be contributing to the problem. Fortunately for you on a desktop you can put in a fast 2.0 usb port card into one of the pci slots on the back of the computer. So, all is not lost.
Mar 22, 2012 | Computers & Internet
I have an HP Media Center PC m7330n. It recently was infected with a host of viruses and rootkits. I eliminated all the viruses and rootkits with a battery of anti-virus programs. Everything works as...
You might want to try to go to the device manager and go to the Universal Serial Bus controllers
Try to uninstall everything and restart the computer.
See if that will let the computer recognise the USB ports.
If that does not work, you might want to reinstall the chipset drivers of your motherboard.
Hope this works for you.
Jun 21, 2011 | HP Pavilion Media Center TV m7330n...
Usb ports do not work. Windows does not recognize them.
IT may be time for a new systemboard. This is a common recall issue with the dV6000. If you wanted to be sure, you could reinstall windows just to verify everything is okay there.
Jan 06, 2011 | HP Pavilion dv6000 Motherboard
Usb ports not recognised
Right click on the yellow flag and uninstall the corrupt driver. Restart the computer, plug a USB device in and it should be resolved. If not post back.
Regards.
Jun 29, 2010 | Gigabyte GA-G41M-ES2L Motherboard
All usb ports on my HP Pavilion dv5000 do not recognise any device attached to them. Hoevevr when thr same devices in pugged into another computer they work perfectly.
Unistalled the USB Generic Root Hub Drivers from the Device Manager by right clicking on the generic root hubs and then restart the notebook and This will fix this issue for you....:)
May 02, 2010 | HP Pavilion dv5000z Notebook
USB ports not working, slow computer
The error you are getting is the USB port driver. I suggest disconnecting ALL of the items you have connected to ALL of the USB ports and rebooting. If the computer reboots normally, go back and install ONE and ONLY one USB device. Restart your machine. If it boots OK, shut down, remove that device and connect another one, restart again. Do this for EACH of the USB devices until you find one that causes the computer to boot slowly and/or generates the error message. That one is the culprit and needs to be repaired before reattaching to your system.
If, however, after removing all of the USB devices initially and rebooting, you still get the error message, then you have a USB driver problem. You will need to remove the USB driver and reinstall from a known good location (like HP's website) to fix the driver problem.
Jan 07, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
Hte usb 2.0 ports are not recognised
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Does the "tree" show any "question-marks"?
Expand the 'USB' branch of the tree.
Does it show that the device-drivers for the USB 2.0 ports have been installed?
Access: http://support.dell.com
and click "detect my system",
and download the offered USB device-drivers.
Dec 01, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Usb device noy recognised
Go into Control Panel and delete all USB references, then reboot.
Jan 11, 2009 | HP DeskJet F380 All-In-One Printer
HP Pavilion dv1000 Notebook Logo
298 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
