Question about Microwave Ovens
My goldstar micro stopped working. No display. it's dead!! Is there an interior fuse and where is it located? Thanks
  • 2,130 Answers
You may have a blown internal fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 28, 2008
Microwave stopped heating #mv1608bb
Open the back and look for a blown glass tube fuse. If the filament is broken, replace the fuse. If it's a solid fuse, do a continuity test. If you have continuity, then it is still good. Good luck!
Jan 17, 2014 | Goldstar Microwave Ovens
Microwave was in use and then shorted out. The breaker did not flip but microwave display went blank and interior light went out. Tested outlet for microwave and it still has power but now microwave is...
There are at least one or too fuses gone, the main fuse located on the main board or behind the control panel, and the thermal fuse located at top on the inner chassis that protects the magnetron, any more than that you are getting into serious money. Remember lethal voltages present when plugged in.
Jun 25, 2012 | GE Microwave Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Completely stopped working
sounds like you blew the fuse inside
Jun 19, 2009 | Goldstar MV-1526 Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Dec 10, 2008 | Goldstar MV-1155 Microwave Oven
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Help-
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor (and fuse).
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer (and fuse).
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
For parts, you can contact LG at 1-800-243-0000 or http://us.lge.com/support/support.jsp
If that doesn't work, please feel free to contact me directly via http://tinyurl.com/yzjozk and I'll help you find a replacement part.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 05, 2008 | Goldstar MA-780M Microwave Oven
My goldstar microwave stoped working. No display, its dead. Is their an internal fuse and where is it located. Thanks
- Jim
Feb 28, 2008 | Microwave Ovens
Microwave just went dead
If there is no display and nothing works it may be as simple as a blown fuse. Try that first but unplug the unit before you do anything.
Oct 02, 2007 | Goldstar MA-7100 Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
