Question about Microwave Ovens
My goldstar microwave stoped working. No display, its dead. Is their an internal fuse and where is it located. Thanks
  • Anonymous Jun 20, 2008
    NEED DISPLAY BOARD PART #SHARP FA649DR
  • priruchi Aug 26, 2008
    gh7155xkb whirlpool gold no display no power fuze was blown
    changed it display turned on set microwave for one second pressed start
    fuze blown again 6 years old please let me know how to fix it thank you
  • 2,130 Answers
You may have a blown internal fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 28, 2008
OVEN IS DEAD NO LIGHT NOTHING
Posted on Apr 08, 2008
Goldstar Microwave - Digital display is dark & does not operate
I would suspect the oven cavity thermostat is open.
We have a similar model's service / repair manual and have uploaded it to our site here for free download to help you with disassembly & troubleshooting.
To order Goldstar / L.G. parts, visit Encompass. Since l.G. / Goldstar does not list part numbers in their manuals, you'll probably have to call Encompass toll-free at at 866-779-5835.
Jan 28, 2010 | Goldstar MV-1526 Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar, MV1515W, builtin- fuse
it is under the casing, you need to remove the casing and you will see them, large power protection and smaller control circuit fuses. the power one may be protected by a black plast sheath
Feb 22, 2009 | Goldstar MV-1615 Microwave Oven
Need help with my Gold Star microwave.
The owner's manual won;t tell you that, only the repair or service manual.
While we don't have that exact model, we do have the manual for a similar model uploaded here.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Goldstar owner's manuals can be downloaded here.
Aug 06, 2008 | Goldstar MV-1515 Microwave Oven
Goldstar MV1502W
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter lead sagainst the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 20, 2008 | Goldstar MV-1526 Microwave Oven
Help-
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor (and fuse).
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer (and fuse).
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
For parts, you can contact LG at 1-800-243-0000 or http://us.lge.com/support/support.jsp
If that doesn't work, please feel free to contact me directly via http://tinyurl.com/yzjozk and I'll help you find a replacement part.
Mar 05, 2008 | Goldstar MA-780M Microwave Oven
My goldstar micro stopped working. No display. it's dead!! Is there an interior fuse and where is it located? Thanks
- Jim
Feb 28, 2008 | Microwave Ovens
Microwave just went dead
If there is no display and nothing works it may be as simple as a blown fuse. Try that first but unplug the unit before you do anything.
Oct 02, 2007 | Goldstar MA-7100 Microwave Oven
Microwave Ovens Logo
276 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
