Question about Car Audio & Video
New System A bought a 12 in enclosed box with a built in amp from Walmart. I connected all the wires but there is no bass sound. what can i do?
  • Chris Busch
    Chris Busch May 11, 2010
    An all in one unit? From wallmart?
    Im not putting you down, my first system in my car was wallmart. i have learned since that alot of there products are cheap for a reason, But lets be sure of what you got and what we can do to fix you up.
    I checked there web site to see if i could find what you describe but they didnt show anything.
    First, Is it one of those boxes that has like two subs and tweaters built into a box that has a set of wire connectors in the back and it comes with a AMP thats seperate that came wiith it?
    Depending on if it came with it or not you may need to get an AMP wiring kit.
    You run a Positive power cable from the battery, which has a fusable link in it, al the way to the amp.
    Then you run a ground from the amp to the chasis of the trunk ( if the amp is in the trunk anyway) or wherever you have the amp at. The shorter the ground cable is from the AMP to the chasis, the less interference you will get from the car and other devices.
    Then you have whats called the remote wire that connects into you cars radio fuse, the one that only has power when you have the car on or in accessories, but not when turned off.
    Then you should have a pair of AV plugs that go from the amp to the CD/radio player. This is for the sound or base. If you have a factory installed system in front, it may not have external base plugs and you will have to wire the sub into the back speakers along with a crossover or high pass filter so only bass gets through to the subs AMP. I havent done it that way before so you might want to read up on it. Instructions come with the AMP wiring kit and they tell yo how to hook it up.
    Let me know exactly what you have and provide a picture if you can of the AMP and the box and the connectors, that way i can better asist you.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
At the bottokm of this link, it will tell you how to install sub. Go over step by step to make sure you did it right.
http://www.ehow.com/how_5829_wire-car-stereo.html
Posted on Mar 13, 2008
How to connect wires to amp
Most amps have 3 places where you need to hook up wires to power them. the 1st is a ground wire that at best is 1 foot long and it goes on the ground or negative 12 volt connection then a bolt on the car you may need to sand off the paint for it to work, 2 a RMT or remote wire that is normally in the middle of the power and the ground connections the remote turns the amp on and off so it needs to go to the remote wire on the radio or a ignition spot on the fuse box - turns on with key on and off when you turn the key off , 3 the power wire is hopefully large 4 gauge wire and goes to the + 12 volt plug on the amp this wire has a in line fuse and goes to the battery and to the amp only. RCA wires go from the radio to the amp and are round and just plug in with no screws some factory radios need a conversion kit you can get at walmart for RCA wires. the speaker wires have some sort of mark or line to tell you what to put were like if you put the line on a negative on the amp you need to put the line on the negative on the speaker box to or it will not bass and could hurt your amp. ask me if you need anything else :) and please rate :/
Sep 04, 2012 | Blitz 1600 Watt 4 Gauge Amplifier...
I just bousght a martin ash home thearer ..how can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
No sound from tweeter bx5a
First of all, never connect the audio from your receiver directly to the tweeter. You can blow the tweeter instantly. The mid-bass driver can be damaged from a direct connection as well.
Since you get absolutely no sound from either driver, this seems to implicate the crossover. If the crossover has opened, no signal gets through, if it has opened early in the signal path.
But, it is also possible that a short exists, and that perhaps your amp cuts off the output having sensed a short. The short could be in the crossover or one of the drivers.
Here are some troubleshooting tips--
To prevent damage to your amp, turn it off while making or breaking any connections inside the speaker boxes.
Write down which wires get connected to which place on the drivers, so you can get them back where they belong.
With your amp turned off, connect the bad speaker to your amp. You've already verified that no sound is produced when both drivers are connected.
So, with your amp off, disconnect one wire from the tweeter in the bad box.
Briefly turn your amp on and listen for sound.
If you get sound, the tweeter is shorted.
If you get no sound, with the amp off, reconnect the tweeter in the bad box and disconnect one wire from the mid-bass driver.
Briefly turn the amp on and listen before turning the amp off.
If you get sound now, but not before, the mid-bass driver is shorted.
If you got no sound either way, check the DC resistance of the mid-bass driver (only, not the tweeter. Ohmmeters put out a small DC voltage to test resistance. That DC voltage might damage a tweeter, maybe. Don't risk it). Ohm the mid-bass driver while it is not connected to the crossover. If the driver is good, you should read some ohms--a little less than the stated impedance. An 8 ohm driver might read 6.5 ohms, for instance. If you get an open or a short (with the crossover disconnected from the mid-bass driver) you have a blown driver. Two actually, since neither the tweeter nor the mid-bass driver produced any sound in the previous tests.
If you can't get ahold of an ohmmeter, try this--
Open the good, working speaker and place the two side by side.
Connect your amp to the bad speaker box only.
With your amp turned off, disconnect the wires from the mid-bass driver in the bad box and connect them to the mid-bass driver in the good box. Disconnect one of the wires from the "good" mid-bass driver first, so you don't have two crossovers connected to it at the same time--even if only one of them will get powered on. It keeps the confusion down to a minimum when trying to isolate your problem. Oh, and disconnect one wire from the bad tweeter, in case it is shorted.
Turn the amp on and listen briefly before turning the amp off.
If you got sound, the "bad" crossover is fine, but the "bad" mid-bass driver is blown. And, since you got no sound in the previous tests, the "bad" tweeter is blown, as well.
If you got no sound, try it the other way around. Meaning--
With the amp off, disconnect the speaker wires coming from your amp from the bad speaker box and connect them to the good speaker box.
Your amp is now connected only to the good speaker box.
With the amp still off, connect the mid-bass wires from the good box to the mid-bass driver in the bad box. Remember to disconnect one of the "bad" crossover wires from its own driver first, so only one crossover is connected to the "bad" mid-midbass driver. Remember to disconnect one wire from the "good" and "bad" tweeters, so the only sound you hear--if any--is from the "bad" mid-bass driver, powered by the "good" crossover.
If this produces sound, but the previous attempts failed, you have a crossover problem.
If you still get no sound, something went wrong and you need to retest the good speaker by itself and back up a few steps and try again.
Assuming you got sound from the "good" crossover while it was driving your "bad" mid-bass, make sure no wires have come loose inside the "bad" box. Assuming you have sound connections at each end of each wire, you now need to desolder the electrolytic capacitors from the circuit board.
Make sure you mark them first, so you can put them back where they belong.
You can remove only one at a time, if that helps.
Use an ohmmeter to check some components.
The big red coil should read pretty close to a short, maybe one ohm.
The capacitors should read open or infinite resistance, although you might see a steadily increasing resistance while the capacitor charges up from the ohmmeter. If you read a steady low resistance on a capacitor after it has been removed from the circuit board, that capacitor is bad and must be replaced. The markings on the capacitor should give you some clues as to the proper replacement.
All things considered, I suspect that your problem is a shorted electrolytic capacitor. But, I gave you all I could think of so you can narrow it down and isolate the problem, whatever it might be.
I hope this helps.
Feb 23, 2011 | M-Audio BX5a Speaker
My car subwoofers work, but theres no bass
turn them off and carefully push in on the cone (gently) and listen for scratching or scraping- push strait in and they should flow freely in and out if they DO without feeling or hearing scraping the subs are probably ok, next its either the amp is not powerful enough or the box is not soundly built, by that i mean its too small for the subs- is the box ported or sealed? if ported try plugging off the vent temporarily and see if bass increases if it does i would permanently seal the box
Mar 13, 2009 | Kicker 06CVX122 12" COMPVX Subwoofer,...
Volfenhag zx-8400 amp and ZX-4712DVX subs
First of what you have should work great together....now the next thing is: does the bose system carry powered speakers if so the spliced speaker wires should be put onto a converter(a small box with RCA outputs) then you should make sure the levels in the little box is not set to full but 75%, if set to full you can be looking at distortion. Then they should set the amps to full range and see what you get.........oh and by the way you don't have to use that little controller(with the telephone wire) for the bass. You can control the bass with the frequency controllers on the amp or your head unit. And it's not a german thing trust me they come with nearly all amps now. These guys are full of ****. If you don't get the punch you want they should try bridging the amp for more of a punchy sound. Oh and you can use that decent sized box with the vent holes......that should work fine.
Jun 15, 2008 | Volfenhag Car Audio & Video
Bass amp for guitar?
i say it can! u would get a nice clean sound! acoustic guitar sounds nice through a bass amp!
you probably wouldnt get distortion out of bass amp though! depends on the bass amp! some bass amps have built in effects! e.g distortion
Oct 15, 2007 | 3Com SuperStack II advanced RPS...
Car Audio & Video Logo
146 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
