Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher. Just had new whirlpool dishwasher installed, worked fine first couple of times,but now seems like its not getting water at the start.checked valve&its turned on .whats the problem?
    President:
  • Whirlpool Master
  • 2,651 Answers
Reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Posted on Mar 02, 2008
2 Suggested Answers
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
I have some problems with a Whirlpool DWF 406 dishwasher: The other day, my wife complained about it not finishing a program (just stopped and started bleeping). I saw a post at this forum where it said to...
We have the same problem. The dishwasher is 10 years old. In one of the German forums they said that usually it's because the sieve ahead of the membrane has a fine layer of sludge and the pump cannot pump out the dirty waste water. They said that you have to dismantle the sieve, clean it thoroughly, re-install it, and it should work just like it always did.
Nov 29, 2010 | Whirlpool Dishwashers
My dishwasher recently started leaving a white, chalky residue on all the dishes. It wasn't gradual at all. One day everything was fine and all the dishes clean and the next they were covered in nasty...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Nov 04, 2010 | Whirlpool Dishwashers
Run times are long and water is not getting hot
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
heatman101
256re
Apr 14, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
It's not cleaning the dishes. Sounds fine, but
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Feb 18, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool gold model GU1500 diswasher. When the rinse cycle ends the water pumps out into the garbage disposal like it should, but then water backs-up from somewhere into the bottom of the...
Seems you answered your own question here. You need to make an air gap in the drain hose - take as much slack as possible and make a curve (upside down U) under you sink as high as you can go. Make sure you clip ot to back of the cabinet to stabilize it. Good luck
Jan 11, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool gold dishwasher is leaving a white milky film on the dishes. My old maytag cleaned fine, so water temp and pressure is not an issue.
Water is the issue.
Replace the water supply valve under the sink and water supply line to dishwasher.
Over time as you can see minerals deposit in the valve and restrict the water flow to the dishwasher.
This is especially inportant on todays water saving units.
Many people replace an old dishwasher and hate the new unit due to a white film left on dishes.
Although you may have paid for a professional installation a new shut off valve is almost never replaced even though the waterline may have been at an additional cost to you..
Jan 09, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher won't wash
pump is likely gone ......without pressure from the pump .the arms will not turn and no water will shoot from the arm jets .....it's kinda like a whirlpool tub that way .....no pump no bubbles ..good luck
Jul 25, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Water Stayed in dishwasher
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 28, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
You probably have a bad water valve.
Sep 20, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Bosh dishwater does not fills with water: seems it shuts down!
you have a leak probably from circ pump. there is a float in the base which when lifted by water, shuts everything down and turns on the drain pump
Jan 29, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Whirlpool GU2400XTP Built-in Dishwasher Logo
154 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
