Question about Lexmark X5150 All-In-One InkJet Printer
Wont install when i try to install it comes up cannot install rcd
  • Anonymous May 13, 2008
    I NEED IT TO DOWN LOADDIDNT HAVE D . I BOUGHT IT AT A YARD SALE AND IT DIDNT HAVE A CD WITH IT
I cabt install my software and it seems not working its a HP deskjet 2360
Posted on Apr 01, 2008
    Genius:
  • 3,587 Answers
Machine displaying general alarm the infuser slide was very tight freed up and reassembled now turning the machine on results in an arc at the motor brushes which blows the RCD breaker.
Hi Chris
Good Job freeing it all up etc. Your 90% there
Can you remove brushes & clean and stretch a millimetre more out of brush leads to stop arcing. Or perhaps the load is to great.
I did notice you said RCD.
RCD's usually only trip when an in-balance occurs between the hot phase wire & neutral wires.
Eg... what goes in via phase wire must come out on neutral wire. Even a small millivolt trickle to ground will trip an RCD. (20-30ma)
The Residual Current Device is for electric shock Safety.
It is not the main fuse or circuit breaker.
RCD's can be a real pain when there is a slight moisture leak.
For Example.
My fridge in my Winnebago would trip the RCD after it hadn't been used for awhile. The insulation around the 10A heating element was damp & tripping the RCD continually.
So how do I bypass the RCD to heat the element up and get rid of moisture. My method was to use a stand alone generator with no RCD to power the RV.
Worked great. Once the element surroundings were dry it ran fine on the home 240vAC.
So... If you really are tripping the RCD then the problem is AC "LEAKING" to Earth. Usually Moisture.....Try a hair dryer
If it is really blowing a Fuse or Circuit Breaker then the problem is too much current being drawn in circuit.
Hope this Helps
Trevor
Apr 07, 2015 | DeLonghi Prima Donna Avante ESAM6700...
Advice on RCD tripping
yes
an accredited electrician can test the circuits for insulation failure , vermin shorting across active / neutral/ earth points and the rcd itself
it is not a diy job
May 12, 2017 | Ovens
How do you do the lectrical wiring for a upright sunbed
Doesn't it just plug into an outlet? You should have an RCD already if you are going to install a sunbed.
If not or if you don't have an earth leakage breaker on your supply then call a qualified electrical contractor who will need to install a RCD for safety reasons I.e preventing death by electric shock.
Jun 17, 2014 | Cameras
Download rcd msi
I suspect you are using a Dell computer. The RCD.msi is Dell's Resource CD installation program. I'd recommend that you contact Dell on how to proceed.
May 03, 2014 | Ahead Software Computers & Internet
I have installed a garden outhouse which has come with a 3kw heater in the roof and has a 3 wire cable hanging from it. I have an RCD external socket to which I've connected a 10m re-enforced 3 wire...
The switch is probably a single pole switch and just switches the incoming live to the output, in your case the live from the RCD to the outgoing live of the heater. The 2 earths can be connected together and 2 neutrals. When you mention the RCD external socket I presume the cable to the outhouse is fitted with a three pin UK plug so check the rating of the I66 switch to ensure it can cope with the 13 amp current which can flow.
A double pole switch would be preferable. This provides total isolation and switches off the incoming live and neutral of the cable from the RCD. This is safer because if anyone ever rewired the plug at the RCD and mistakenly reversed live and neutral, a correctly wired single pole switch in the outhouse wouldn't switch off the live and this would be a hazardous situation, especially since the heater is in an outhouse which could be damp.
Jul 22, 2011 | Garden
We have just bought a very old house that has a Vulcan Oil heater installed in the fire place. We have tried to light it (but all houses are now by law have installed RCD switches at the meter box,) How...
Is the RCD sensing a leak to earth?
As a test, you could drop the earth wire off the unit and see if the ignitor then works. If it did, then you would need to figure out if there was somewhere else you could earth the unit. This would potentially leave the ignitor without an earth and you need to decide what to do about that.
I hope you can see that I'm absolutely avoiding advice that you remove the earth from your unit in order to make it function. What you should do is get a professional in to correct the fault. What you actually do is a matter for you.
Jul 07, 2011 | Heating & Cooling
How to record cds using the Sony RCD-W500C
Hi, Try downloading the manual in PDF format from the following location. All the explanations are included. http://www.google.co.il/search?aq=1&oq=RCD-W500C&sourceid=chrome&ie=UTF-8&q=rcd-w500c+manual
Regards, Icom1
Apr 04, 2011 | Sony RCD-W500C 5-Disc CD Recorder
My ryobie bench grinder keeps tripping the rcd within a second of turning it on?
Assuming your local tech confirms that your bench grinder tests ok. The problem is probably that the grinder draws too much current for the RCD and is therefore detected as an earth leakage. High amperage devices often do that. Your best bet would be to plug it in to a socket which is on a non-rcd circuit. Maybe you have an RCD on the whole house though? I would start with returning the grinder and trying a different brand with a lower amperage/wattage rating. If that doesnt work, I would call an electrician to discuss installing a different RCD or running a separate circuit for your power tools.
Mar 03, 2011 | Jet Industrial Bench Grinder 6in new
How do i reinstall operating system from recovery
SCD=system disk, boot off that. It will start the recovery process.
RCD=recovery disk, will prompt you when to install those. This is the system image to be restored.
Remember, whatever's on there now will be wiped!
Jan 18, 2010 | Acer Aspire 3610 Notebook
Sony RCD-W500C
Hit finalize, then "yes".
Aug 17, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Lexmark X5150 All-In-One InkJet Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
