Question about Canon PIXMA iP90 Mobile Printer
Power wont on
My printer power wont turn on, the power is turn on for a second only if i keep it off for a day, but then go off again, what should i do...??
  • rcmike777 Apr 27, 2008
    My iP90 will occasionally not power on. It will work just fine for 5 or 6 days, then again, not power on. When it would not power on, I tried swapping power supplies (from another iP90) and no go. This is not in keeping with Cannon's reputation for quality and reliability. My printer is only about 1 year old, but no longer under warranty. What could be the problem?
  • Elliefish Jan 26, 2009
    My printer won't turn on either, when i turned it on yesterday it did say the battery was exhausted but i have plugged it in all day yesterday and it still won't turn on
    President:
  • 2,072 Answers
You have a bad power supply. That would have to be replaced.
Posted on Feb 28, 2008
How do I fix our Printer?
Tebogo,
This sounds like a power supply problem to me.
I would get in touch with Xerox concessionaires as soon as you can it could be a faulty power supply or one which needs upgrading perhaps. If it's not too old then I'm sure theres a fix.
Good luck.
Apr 30, 2015 | Xerox Phaser 3635MFP/X Multifunction...
ERROR CODE C-3852
Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit/ High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 06, 2014 | Konica Minolta bizhub C250 All-In-One...
Bizhub 751 c 3803
Sir/Mam,
Turn off the main both power switch one located inside the front door, second on the control panel, then wait ten seconds. then turn on main inside first. Then holding down the utility/counter button turn the sub power switch on. You must keep the utility button down The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit check. Have a qualified tech look at it. :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! Fire could occur that would ruin a perfectly good day!!!!
Jan 08, 2014 | Minolta bizhub 350 Black and White Copier
Error code c-3452
try only once
If the code comes back, you need a Fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Jan 07, 2014 | Konica Minolta bizhub C250 All-In-One...
PS3 wont reboot when I hold the power button down for 10 seconds. There are no lights going on at all. There are a flash of red lights on the controller for a few seconds and then they turn off also
okay do this again turn your ps3 off.Then you hold power till it turns on then keep holding until it turns off.Then do it again till it beeps 2 times you have to be quick or it wont work.If this dont work you need to send your ps3 in for repair as the power port may bhe faulty or power board.I could fix this if i had the ps3 right on hand i do have the newest ps3 and havent had any problems yet.get back at me with more info on this.if it works or if it dont still get back at me.
Mar 22, 2013 | Sony Playstation 3 (PS3) Console
I have an HP F4480 printer and i have used it before. I haven't used for days and when i used it again a problem occur. As i plug the power cord to the outlet, the power button keeps on blinking even if i...
Hi. Try pulling the ink cartridges out of the printer, turn printer off, then on again. When asked for ink cartridges, insert only one at a time.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 01, 2017 | HP F4480 All-In-One Printer
Deskjet 3745 power light flashing green, wont print
Hello thanks for using fixya
You should try this solution:
Remove the power cable from the printer, Press power then wait a few seconds, then Press power again. Now plug in the power cable and try to turn the printer on, It will boot, If it does boot then it means the power supply is not exactly correct in printer. So you may need another power supply
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 23, 2011 | HP DeskJet 3650 InkJet Printer
The used ink tank is full. Cancel printing and turn the printer off and then back on. If this doesn't clear the error, see the printer manual for more details. error keeps appearing and wont print
just follow this steps to fix this,
1. Hold RESUME then press & hold POWER
2. Release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for reset waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | Canon i250 InkJet Printer
Printer wont start up properly. Status bar keeps scrolling and power light keeps flashing.
HP recommends rebooting.Turn off the printer,unplug for 60 seconds.Plug it back in,and restart.It's worked for me!
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer 1270 front control panel lights are flashing constantly and the printer wont move or react to any manual inputs
Turn the printer off.
Press down the ink button and the paper button at the same time and turn the printer on (while keeping them pressed down)
After a second or two, the red paper light should start flashing.
Immediately release the buttons and press and hold the paper button again. Keep the paper button down for about ten seconds and release. After a second or two, the printer should go back to it's normal state.
Please try this and reply me for further doubts.
Regards, Nandini.
Sep 14, 2009 | Epson Stylus Photo 1270 InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
108 people viewed this question
old marine
old marine
