HELLO8)IS A RAIDMAX AZTEC w/500W CASING GOOD.CAN THE POWER SUPPLY SUPPORT A SYSTEM LIKE BELOW
AMD PHENOM II X3 710
COOLER MASTER HYPER 212 PLUS
HIS RADEON HD5770
KINGSTON VALUE RAM 800MHz 4GB RAM
GIGABYTE GA-MA78LM-S2H
COOLER MASTER SILENT 120MM HIGH PERFORMANCE/BLUE LED x6
THNX FOR ANY HELP8)!
Good Day
The same model also comes standard with a 390w power supply. However it all depends on what you are using the Desktop for, what you want the power supply features to do and what you install in the casing. Amything above 390w will do for general desktop work. If a gaming desktop, anything above 500w should do. You should obviously use the same brand Cool Master power supply but most brands should fit. Take a picture of the back of the case where the power supply fits and take it with you to a store if not sure.
here is a ling to give you some ideas. http://www.coolermaster-usa.com/category.php?category_id=22
regards
Shaun
