Question about Toshiba gigabeat S MP3 Player
Driver files for Toshiba Gigabeat MES30VW
I am not able to connect my Toshiba Gigabeat MES30VW PVP to PC. I tried installing Gigabeat Room (from internet) in my WinXP based PC but the PC does not recognize the player even after connecting it. Could anyone please help me out of this problem. Thanks & regards.
Suresh B.
  • melody76 Mar 14, 2008
    cannot install the cd driver on my computer, not supported language message always appears...
  • Ratpac05 Apr 14, 2009
    i have the exact same probelm except when i plug mine up to my computer it wont reconize it and when i turn it on it shows me a little widows xp sign on the top of my gigabeat player
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
Got dropped and top of player won'tsnap back shut. can u get new outer cases
Posted on Sep 27, 2008
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
How can I get installation CD for my Gigabeat model MES30VW, my previous computer died and I do not have disk
go to the website for toshiba using google or just google "gigabeat room 3.0 " it works fine with vista just follow the instructions
Sep 09, 2009 | Toshiba Gigabeat MEG-F20S MP3 Player
File transfer Problem
Ok, I figured out a solution on my own.
Remarkably simple - all I did was reformat the player again and then reinstall windows media player.
Although in my travels I came across an article which may help users with a similar problem: http://support.microsoft.com/kb/911091/en-us#appliesto
Apr 20, 2008 | Toshiba gigabeat S MP3 Player
Toshiba Gigabeat
try using windows media player it does work if you go to the setting file on yor f20 and slect media player in the pc connections folder
Apr 20, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Contents list
Create a playlist of the songs you want. You will still be able to browse by the other categories like artist, album, etc...
Oct 22, 2007 | Toshiba gigabeat S MP3 Player
Computer does not recognize Gigabeat Device
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat F40
Toshiba Gigabeat support is 1-877-250-8595
Sep 29, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
I have a Gigabeat V30
when you swap the hard drives did you copy the software (not music) from the old to pc.......this is the software that is needed to be on the(that you would have paste to the 80) before your place any other files on it.............
Mar 05, 2007 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba gigabeat S MP3 Player Logo
1,373 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
