Question about Microsoft Windows Vista Ultimate Edition
How do I configure bluetooth on blackberry and vista
How do i configure
    Sergeant:
    Champion:
  • 306 Answers
You have to have a bluetooth adapter attached to the PC....vista will do the rest.
Posted on Feb 28, 2008
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
My blackberry curve recognizes the LG HBM-570 headset, but the headset keeps telling me it is terminating. It has worked for 3 months and just started doing this.
Hi, to solve this problem, you will have to do some troubleshooting.
First you will need to disconnect the pairing of both the blue tooth headset from your black berry phone.And pair again with the below instruction.
Instructions
Tips & Warnings
After that if still does not work that means you will need to test if the bllue tooth headset is really not damaged by using it on another phone to confirm.
You can also reset the blackberry cell phone if still not working. Blue tooth might be corrupted and will not connect to headset. You can use the below instruction to reset cell phone:
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
When you are through with that and still nothing happens, then you blue tooth headset needs replacement..
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Feb 18, 2011 | LG HBM-760 Bluetooth Headset
I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
Hi,Instructions on how to pair blue tooth device with black berry.
Tips & Warnings
Have a nice day .
Feb 16, 2011 | Jabra BT125 Headset
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Tips & Warnings
Good luck to you..
Feb 01, 2011 | Cell Phones
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Tips & Warnings
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
My blackberry bold 9700 bluetooth is not compatible with my laptop windows vista sp1. I am unable to transfer my pictures or music files to my blackberry via bluetooth. how do i solve this problem?
you have to select the option "receive via bluetooth" to be able to receive files to your phone. this can be done when you are in the media folder. press the menu button, then select "receive via bluetooth" when sending files from your pc/other phones.
Apr 06, 2010 | RIM BlackBerry Bold 9700 Smartphone
I cannot send pictures from my blackberry storm,
You receive a Failed to Find Service message when you attempt to transfer a media file between two BlackBerry Pearl smartphones.
The BlackBerry Pearl smartphone receiving the media file is not properly configured.
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
Nov 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
How to open ethernet??
Task 1 - Turn on the Discoverable option on the BlackBerry smartphone Complete the following steps:
  1. On the Home screen of the BlackBerry smartphone, click Options > Bluetooth.
  2. Display the menu and click Options.
  3. Set the Discoverable field to Yes.
  4. Display the menu and click Save.
Task 2 - Pair the BlackBerry smartphone and the computer On the computer, complete the following steps:
  1. Go to Control Panel > Bluetooth Devices.
  2. Click Add.
  3. Select the My device is set up and ready to be found check box, and click Next.
  4. When the BlackBerry smartphone is detected, select the check box next to the BlackBerry smartphone, and click Next.
  5. Select the Let me choose my own passkey option.
  6. Type a passkey in the field provided, and click Next.
  7. On the BlackBerry smartphone, type the same passkey from Step 6, then click the trackball.
  8. On the computer, when the Completing the Add Bluetooth Device Wizard screen appears, click Finish.
  9. On the BlackBerry smartphone, when prompted to accept an incoming Bluetooth connection, select Don't Ask Again, and click Yes.
Task 3 - Set up the Internet access point name (APN) Note: You only need to perform this task the first time that you set up the Internet APN.
Note: If you are running Windows Vista, select Classic View.
  1. Go to Control Panel > Phone and Modem Options.
  2. Select the Modems tab.
  3. Select Standard Modem Over Bluetooth Link, and click Properties.
  4. Select the Advanced tab.
  5. In the Extra initialization commands field, type the following: AT+CGDCONT=1,"IP","<your Internet APN( for eg: aircelgprs)>"<cr>
Task 4 - Configure Dial-Up Networking Note: You only need to perform this task the first time that you configure Dial-Up Networking.
  1. Go to Start > Settings > Network Connections.
  2. Right-click Bluetooth DUN connection, and select Properties.
  3. Select the Networking tab.
  4. Select Internet Protocol (TCP/IP).
  5. Click Properties.
  6. Click Advanced.
  7. Select the General tab, and clear the Use IP Header Compression check box.
  8. Click OK to close all open windows.
  9. Go to Start > Settings > Network Connections.
  10. Double-click New Connection Wizard.
  11. Click Next.
  12. Select Connect to the Internet, and click Next.
  13. Select Set up my connection manually, and click Next.
  14. Select Connect using a dial-up modem, click Next.
  15. Select Modem - Standard Modem Over Bluetooth link, and click Next.
  16. If the Select a Device screen appears, select the Modem - Standard Modem check box, and click Next.
  17. Clear the ISP Name field blank, if necessary, and click Next.
  18. Complete the appropriate step below:
    • If the BlackBerry smartphone operates on General Packet Radio Service (GPRS) or Enhanced Data Rates for Global Evolution (EDGE) networks, type *99# in the Phone number field, and click Next.
    • If the BlackBerry smartphone operates on Universal Mobile Telecommunications System (UMTS) networks, type *98# in the Phone number field, and click Next.
    • If the BlackBerry smartphone operates on Code Division Multiple Access (CDMA) or 1x/Evolution Data Optimized (EVDO) networks, type #777 in the Phone number field, and click Next.
  19. Type the user name and password provided by your wireless service provider. If your wireless service provider has confirmed that this information is not required, leave the fields blank. Click Next.
  20. Click Finish.
Task 5 - Connect the computer to the Internet using Dial-Up Networking Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session may interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Click Start > Settings > Network Connections > <Name of the new connection>.
  2. Type the user name and password provided by your wireless service provider. If your wireless service provider does not require this information, leave the fields blank.
  3. Click Dial.
Oct 05, 2009 | RIM BlackBerry 7730
How do I install a motorola bluetooth to my 8310 blackberry. i can't get it to configure. states device not found
Feb 28, 2008 | RIM BlackBerry 8800 Smartphone
Microsoft Windows Vista Ultimate Edition Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
