HP Compaq Business d530 PC Desktop Logo
Anonymous Posted on Feb 20, 2010
Ive got a hp compaq d530 it has a pentium 4 inside can i take the processor out of this machine and stick it on another board im trying for the first time to make my own gaming system, what type of new motherboard would i need i know the hp is more of a buisness pc it also has a hard drive could i use this as well in fact what could i use cheers
Anonymous
Level 3:
President:
  • Master 548 Answers
  • Posted on Feb 20, 2010
Anonymous
Master
Level 3:
President:
Answers
548
Questions
0
Helped
179342
Points
1846
You can take it from that machine, but you will need the same type of socket on the motherboard. The socket for that type of processor is Socket 478. You need to look for a motherboard that has this type of socket. Also look for Ram and make sure the new board has exactly that type if you want to take the memory from the compaq. The same operation for the VGA card, again if you want to take it from the compaq. You can use the hard drive from the compaq without a problem. You can connect also another hard disk
Hp compaq pd1068p driver download
so , you meant ? "where can I" ? as in a real question?
Abdellatif Ziati wants answers to this question , hyJacking 2013 posts to the wrong forum D530??
NO OS stated, and drivers match, OS, windows what.
and what fails, what feature fails,,
the PC D530 is obsolete and HP has no support now for it.
so google all day long and find it, and get the PC infected.
ive no idea what pd1069p is.... nor does HP searches find it.
the D530 is 14 year old now. an old Pentium 4 box.
some came with windows 2000, (17 year old OS)
here is the old data sheet on this Relic PC.
http://www.hp.com/ecomcat/hpcatalog/specs/emeapsg/99/D530SERIES.pdf
we take these to the dumps, and give it the last rights. RIP
1helpful
Time of this report: 5/23/2011, 15:20:31 Machine name: MIRO-PC Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255) Language: English (Regional...
The embedded video chip in this pc or the optional add-on video cards that were offered with it are extremely old models, that are just Dx8 compatible. Win 7 need a video card that is at least Dx9.2 compatible = you will need to upgrade your video with something like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7189043&CatId=318
I need de manual Motherboard SP323091-001 Thanks
http://www.manualshark.org/m/hewlett-packard-hp-compaq-d330-desktop-pc-technical-reference-guide-for-hp-compaq-d330-and-d530-personal-computers-featuring-the-intel-pentium-4-processor-and-intel-865g-chipset-28293/
Download of the PDF is in the link
Rodrick!
2helpful
How do I reboot a HP Compaq d530 in Safe Mode?
Tap the F8 Key repeatedly once you see the HP logo.
17helpful
2answers
Missing or invalid processor microcode update. Please contact HP company for a new microcode update to support the new processor stepping ...
1helpful
Dear sir i have hp d530 ssf system and 3.00 ghz proccesore and 1gb ram when i start my pc then system ask update microcode update my pc version is System Manufacturer: Hewlett-Packard System...
  1. Click Start, right-click My Computer, and then click Properties.
  2. Click Device Manager.
  3. In Device Manager, expand Processors.
  4. Double-click the processor, and then click the Details tab.
  5. Click to select the Hardware Ids in the drop-down list.
  6. Examine the information in the details pane to determine whether the computer uses an older Intel Pentium.
2helpful
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Troubleshoot D530 Pentium 4, i get the boot screen, over n over
Run hard drive tests, if HD tests good, and no data to keep, restore os from restore partition with f10. If data needs kept, run a repair installation of os. Run fixboot and fixmbr commands from prompt. Also try sfc/scannow from command prompt.
3helpful
2answers
Pentium 4 upgrade
The Compaq Presario SR2011WM supports following processors:
CPU/Processor
  • Socket: 775
  • Supports the following processors:
    • Pentium D 900 series Dual Core (Pressler, 65nm)
    • Pentium D 800 series Dual Core (Smithfield, 90nm)
    • Pentium 4 601 series (Cedar Mill, 65nm)
    • Pentium 4 600 series (Prescott, 90nm)
    • Pentium 4 500 and 501 series (Prescott, 90nm)
    • Celeron D series (Prescott, 90nm)
Hope it helped.
Processor Upgrade
did you reset the bios first. ? (id pull the coin cell)
you did all that backwards , the steps are.
1: read the HP service guide see all processors supported.
its a short list. its not like changing light bulbs.
2: the BIOS must support that precessor too.
3: the upgrade if possible , SEE?
d530 SFF, is a small form factor desktop.
it came with
my guess is you want the 3.3mHz version. ( a wasted effort and cash in my opinion the ,it is only fractionally faster, (go for 2 or 4 cores and win)
these old PC are mostly NOW scrapped, gone, nobody wants them.
for good reasons. (no support and no parts, and slow as slug)
worse is it runs XP the dead, now, virus magnet.
support at HP says.
HP COmpaq EVO Business D530
circa 2003, 14 years young?
some sold with Windows 2000. ! ouch and Mandrake 9.1 Linux - Light and OS/2...
specs. that matter
Intel 865G Chipset
800-MHz, 533-MHz or 400-MHz FSB (front side bus limits)
and the memory must match it. speed wise.
the parts surfer (HP ) shows it cam with 17 processor options.
sold newer, the full p/n in the service tag tells this.. not told by you.
some Celeron and other P4s.
the fastest one is, (HP P/N#)
335813-001
Intel Pentium 4 processor - 3.20GHz (Northwood with Hyper-Threading, 800MHz front side bus, 512KB L2 cache, FCPGA2, Socket 478)
the problem with that is the BIOS, many times the newer faster
the hp support page is active.
the last BIOS update is for just this, processors
eg: BIOS 109
Updates Intel Pentium 4 Processor microcode for F41, F34, F29 and F49 steppings. (cupid app shows this)
getting the BIOS correct first is hard.. due to variances, in mobo
https://support.hp.com/us-en/drivers/selfservice/hp-compaq-d530-small-form-factor-desktop-pc/316713
lession1:
when PC boots, the BIOS scans many thing but CPU is #1
it scans it to see if it recognizes, it.
if it can not do that, (not in its old 2003 list) then it defaults to slowest CPU support, what else can it do?
the it sets up clock rates properly, this is super basics in PCs.
Then it scans the memory sticks to see if they can run at this clock rate, if not it goes to slow speeds. (what else can it do ?)
it will go to the slowest ram stick inserted. speeds.
or to slowest processors you have actual.
that is all.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
