Question about HP LaserJet 9040n Printer
HP 9040n NOT RESPONDING
I HAVE A HP LASERJET 9040n CONNECTED VIA NETWORK PORT.IT HAS AN IP ADDRESS AND ABOUT 10-15 PCS CONNECTED TO IT.
RECENTLY WHEN USERS SEND JOBS TO THE PRINTER IT TAKES VERY LONG TIME FOR THE PRINTER TO RESPOND OR SOMETIMES IT DOES NOT RESPOND AT ALL.
I HAVE TRIED TO CHANGE THE NETWORK CABLE AND SWITCH OFF THE RAM DISK YET NO RESULT.
SOME1 PLS HELP ME OUT!
  • 1 more comment
  • clemhova Feb 28, 2008
    THANKS BRO,BUT I HAVE ACTUALLY DONE ALL THAT BEFORE I CAME TO FIXYA.I TRIED THREE DIFFERENT TRUSTED CABLES THAT WERE WORKING ON PCS YET NO RESULT.I HAVE PINGED THE PRINTER IP FROM DIFFERENT PLACE I THE NETWORK YET SAME PROBLEM
  • clemhova Feb 29, 2008
    it was normal,i dont think itz network problem.
    1MS
  • 108 Answers
Try connecting this printer to a different network wall point in the building. If still no change then move back to original wall point and try changing the connection at the Switch end in the comms room.
If still having problems then try pinging the printer to see if it gives time out or execessively high pings. Got a PC on the network and in windows open a "command" prompt and type ping -t XXX.XXX.XXX.XXX where the address of the printer should be place of the x's.
If linux open a console and type the same thing ping -t XXX.XXX.XXX.XXX.
Regards
Please dont forget to rate!
Regards
Posted on Feb 28, 2008
  • dan muggeridge Feb 28, 2008
    What were the ping time responses?
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
Jul 31, 2012 | HP Office Equipment & Supplies
My hp laserjet p4015n is connected directly to the network via ethernet however i can't locate the printer and add it through control panel or even by running its ip address
Hi
click start
printer and faxes
add printer
choose local and remove the check from automatically detect
then click next
mark create new port and choose tcp/ip
the add new port wizard appear ..
enter the printer IP and dont change the second text its automatically
and install the driver for your printer
that's all
Note:
sure that your IP address in the same network with printer
Apr 26, 2011 | HP LaserJet P4015N Printer
I want connect my lexmark e260dn with ethernet cable, but is not in same network range. How to solve this problem
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.xxx then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
Mar 02, 2011 | Lexmark E260dn Laser Printer
How can i configure the IP for the printer HP laserJet P2015dn? what is the address that I can access this printer from my PC via web brower?
For configuring the IP address on the printer, you will have to browse the printer menu, and the IP or TCP/IP should be under Network. Here is basic information about troubleshooting network issues from HP website.
Once you have set up an IP address to your printer you will be able to connect from PC via the web browser by typing in the IP address of the printer.
Dec 15, 2010 | HP LaserJet P2015dn Printer
HP Laserjet 4050Tn can't be found by network computers (XP)
To install the HP as a network printer you need to do the following -
1. Configure the HP's IP address so it matches the IP range of your network. eg if your IP's are 192.168.0.xxx then set the HP to a high number say 100.
3. Connect the printer to the network hub/router and power up the printer.
4. Click on Printers an Faxes - right click on the HP printer and click on Properties.
6. In available ports - click on Standart TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's IP address.
8. Click OK and tick Enable bidirectional support and then OK
You need to setup the HP printer the same way on every computer on your network.
Sep 02, 2009 | HP LaserJet 4050tn Printer
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
HP LASERJET 9040n not r4esponding
ok man in system how many printer are installed if u have two printer intalled u have to set ur laser pariner as a defolt printer then after try to print in your network ur laser printer is a defolt printer so try it
Feb 26, 2008 | HP LaserJet 9040n Printer
HP LaserJet 9040n Printer Logo
133 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
