Question about Microsoft Xbox 360 Console
Xbox doesnt read disks
my xbox powers on fine and i was playing COD4 on it last last. it suddenly said the disk was unreadable. fair enough, i thought. anyway i tried the game again but it sstill wouldnt work. ive now tried all my games but all it says its reading but then it says open tray like it doesnt recognize there is a disk in the drive.I have asked around and it say that it could be the laser which has gone. Help Needed !!
regards,
keir =]
  • Anonymous Jan 27, 2009
    That did not help
  • otters36 Jan 28, 2009
    I too have the same problem. Have found that slapping the top left corner while loading the disc helps although it doesn't always work. Would like advice as the problem is getting worse.
    Scholar:
  • 35 Answers
Microsoft Xbox have some common problem like red lights, E74 and Disc Read Error. Microsoft is providing extended warranty for red lights problem, Means you will have to spend some money in order to get this problem repaired from Microsoft also you will have to wait for 3-4 weeks to get your Xbox back. There are many reasons disc read error can occur in your Xbox like your disc might not be clean, laser might also be dirty and many more common problem. I would suggest you to first clean out the disc, you are using. If that don't solve the problem you can also take the help of DIY guide available at Internet. I think you have got good no. of options to get your Xbox repaired, Choice is yours.
Posted on Mar 07, 2009
  • 108 Answers
If you have a Hard Disk Drive or Memory attached to the console, turn the console off and remove the Hard Disk Drive (HDD) unit and any attached Memory Unit (MU), then switch on your console and try the disc again. If this seems to resolve the issue, turn off your console, attach the HDD and MU again, and then delete any saved games for the game that is causing problems.
Note If it is possible to do so, save the games to a separate MU.
To find out how to remove and connect the Hard Disk Drive from your console, see the following Microsoft Knowledge Base article:
906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive
Don't forget to rate!
Posted on Feb 28, 2008
I'm thinking my disk drive doesn't spin fast enough, but whenever i put a disk into my xbox, it says the disk is unreadable. If i leave the xbox on for about 20 minutes or so, the game plays like normal....
The laser has developed a "kink" brightness will fluctuate
as much as 30% relative to heat.
A new laser will more than likely remedy the problem.
The lasers are cheap and fairly easy to install yourself
Or have a shop swap it out for 50.00-70.00.
If you have any questions feel free to ask
Rob
Aug 23, 2010 | Microsoft Xbox 360 Console
"This Disk Is Unreadable"
Ok lube the guides , good proactive approach, I like that.
Max , I think it's the laser getting weaker and having trouble
locking/reading games .The good news is laser are fairly
cheap 20.00-30.00 and readily avalable , and not to hard to install
if your so inclined .
Jul 03, 2009 | Microsoft Xbox 360 Console
It will read some disks but not all disks and the ones it readds i try to play latter and it dont read
i had this problem with my xbox and its due to either the laser or the magnet within the disc drive that holds the disc in place. the magnet may have come loose which mean u can either open the drive up to try and reposition it, or replace the drive all together. my suggestion would be to send the xbox to microsoft if under warranty or send it to a third party company to see if they can fix it. buying a new drive for your xbox involves some very complex firmware flashing which is not advised
Jun 02, 2009 | Microsoft Xbox 360 Console
Cant play games
If its not doing anythng you may have a hard disk problem? I cant guarante this as you have not given enough information. Do you get an error message? or any message at all other than cant read disk? you are obviously using the internet...take a look at the microsoft.com website....put into the search 'XBOX360' see what is comes up with..you may find your answer there.
Dec 12, 2008 | Microsoft Xbox 360 Console
Keeps saying disc unreadable
"A temporary solution" If u got the new xbox experience and enough HDD space, install game to HDD and then play from HDD. You'll probably have to send back to Microsoft eventually. Though make sure its only COD4 thats giving trouble, buy some disc cleaner and see if that helps
Dec 09, 2008 | Microsoft Xbox 360 Console
Unreadable disc
It might be a problem with the disc itself. Try conventional disc cleaners and repairs. If those don't work, replace the game. If it still doesn't work, then you might need to send the console back to get it repaired. If you're still under warranty.
Jun 07, 2008 | Microsoft Xbox 360 Console
My X-BOX 360 has disk tray errors.
Try clearing the cache....!
To clear the cache on the Xbox 360 do the following:
* Go to the Xbox Dashboard, select the System Blade, and select Memory.
* Highlight the HD symbol and press Y.
* Press X, X, Left Bumper, Right Bumper, X, X.
You will see a confirmation message to confirm system maintenance, proceed.
Clearing the cache on the Xbox 360 is a fairly simple process, and can be useful if the system seems sluggish, unresponsive, or you just need to get rid of a game update (for whatever reason).
The most important part of clearing the cache is knowing what to expect. All downloaded game updates will be removed. So if you have downloaded an auto-update for a game, in order to play it on Xbox Live you will need to re-download it.
User game saves, profiles, demos, videos, etc. are not deleted during the process.
Cheers
Jun 03, 2008 | Microsoft Xbox 360 Console
XBOX 360 ASSESINS CREED UNREADABLE DISK
I do believe its a problem with the disk. The disk may not be scratched or anything but it could possibly something internally wrong with it. I'd take the disk back and exchange it. Hope this helped! Have a great day!
Nov 29, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
63 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
