easycap was not meant to used on windows 7 (i think). but i have uploaded all my easycap drivers for you,.... as always right click exe's and in compatibility mode for windows xp service pack 2. if it still not working after driver install go device manager try update drivers from there.
easycap reccomend - ulead video studio for video editing.
the rar file has no passwords. easycap driver and stuff
Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD: Startup using Last Known Good Configuration to undo recent registry and driver changes. Use System Restore to undo recent system changes. Roll Back device driver to version prior to your driver update.
Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return hardware settings to default in Device Manager. Unless you have a specific reason to do so,the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If this doesn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
The most important Blue Screen of Death troubleshooting step you can take is to ask yourself what you just did. 1) Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD:Startup using Last Known Good Configuration to undo recent registry and driver changes.Use System Restore to undo recent system changes.Roll Back device driver to version prior to your driver update. 2) Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector. 3) Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error. 4) Return hardware settings to default in Device Manager. Unless you have a specific reason to do so, the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death. 5) Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs. 6) Use a system utility tool like Reginout for an instant fix.
The most important Blue Screen of Death troubleshooting step you can take is to ask yourself what you just did.: 1) Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD:Startup using Last Known Good Configuration to undo recent registry and driver changes.Use System Restore to undo recent system changes.Roll Back device driver to version prior to your driver update. 2) Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector. 3) Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error. 4) Return hardware settings to default in Device Manager. Unless you have a specific reason to do so, the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death. 5) Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs. 6) Use Reginout to fix BSOD stop errors
Have you tried finding the right drivers for the device? Once the drivers are installed, the device should work fine with all software that supports video capture, including movie maker.
Goto youtube.com. and search:How to get EasyCap Drivers or http://www.megaupload.com/?d=W64LW1DJ and type in the 3 LETTERS.Wait for the free download on the right side.After I installed the Syntek STK 1160 drivers I still could not capture.THIS STEPS SOLVED IT:
1.OPEN THE ULEAD VIDEO STUDEO PROGRAM 2.CONNECT THE EASYCAP USB DEVICE 3.ON TOP CLICK CAPTURE 4.IN THE MIDDLE CLICK CAPTURE VIDEO.5.UNDER THE WORDS:CAPTURE FOLDER, CLICK ON OPTIONS (THE LITTLE ROUND GEAR OBJECT) 6.CLICK VIDEO AND AUDIO CAPTURE PROPERTY SETTINGS 7. CLICK SOURCE 8. MAKE SHURE TV SYSTEM IS THE ONE IN YOUR COUNTRY 9.CLICK OK.10.A BLUE SCREEN APPEARED AND WHEN I PUSHED THE PLAY BUTTON ON THE DV CAMCORDER I COULD CAPTURE THE VIDEOIMAGE ON THE LEFT SIDE.
WHEN I INSTALLED THE ULEAD PROGRAM I DID SELECT THE TV SYSTEM IN MY COUNTRY(PAL) BUT WHEN I DID STEP. 7, I SAW IT WAS (NTSC).JUST FOLLOW THE STEPS.GOOD LUCK.I SOLVED MY PROBLEM IN 6 HOURS :p
I have windows vista and my drivers load fine. Plug in the unit and the drivers load. I have the 4 camera easycap and the VCR easycap.
Install drivers first before plugging in the unit. Restart computer, plug in unit, check device manager if there is a stk1150 loaded under image.
My problem is getting small files from the recordings. I converted 2 mins of my daughters dance solo and it turned out 1.7gb AVI file without sound. Changing the options to mpeg or WV files will crash the program becuase something doesn't match. I need to play with it more to understand it better.
Hi
I had the same problem. No picture and no sound.
Here is what I did to solve it.
1. I Un-installed the software and restarted the computer. 2. Placed the installation CD (that came with the product) back in the CD drive. 3. Click on "Install Driver" (this only installs the USB 2 drivers so that the computer can see the device)
Make sure you do not attach the Easycap Device before you have installed the USB Driver (as above).
4. Once USB Driver has been installed then plug in the Easycap USB Device, windows should then detect the new device, to make sure:- 5. Right Click "My Computer" "Properties" "Hardware" "Device Manager" check "Imaging Device" (which is where my STK1150 Driver was installed) and make sure it has no yellow exclamation mark next to it.
6. Go back to CD and "install the Uplead Software", you then have to Restart the computer.
Once all installed you can then connect your external device VHS Player/Camcorder etc to the Easycap device, using the Red/Yellow/White leads.
I like many before me, tried and I tried to get the image to play on the software "Capture" screen but all to no avail, I was pulling my hair out, I wasted two days on it, I finally decided that this product was a total load of rubbish and I had wasted my money and it had to go.
Then a major break through, some smarty pants made the comment about INPUTS & OUTPUTS, my prayers along with many others could have been answered ??....
I had actually plugged the Red/Yellow/White leads into the INPUT terminals of the external VHS Player, when they should be plugged into the OUTPUT terminals of the external VHS Player/Camcorder.
On a Camcorder the RED/Yellow/White terminals are usually Output terminals but on a VHS Player they are usually always Input only !!....
I tried running my Camcorder through the software and Hey Presto that worked a treat.
So in order to get my VHS to play through the software I ended up having to buy a Scart OUT (very important "OUT") Red/Yellow/White adapter (see link for product image)
