Monitor problem or?
My computer broke so i plugged my blcd monitor into my old pc till i could fix it.there was a line vabout 3cm wide of horizontal lines flickering running straight down the center of the screen like a barcode.
i cgot my pc fixed and plugged the monitor back into the main pc and the barcode is still there. it makes windows , web pages etc really hard to read. hqave i bust my monitor?
  • mcbonley Feb 28, 2008
    sorry i should have said, my system is a high spec quad SLI gaming system running windows xp. it has been happy with no probs for about a year. while my pc was being serviced i plugged the lcd monitor into my old pc tempory just to get my email etc thats when i first got this barcode problem. i figured what you told me above. and the problem was the old system.
    but when i plugged the monitor back into the gaming system (which never had vthis problem) the barcode was still there. i havent changed canhy hardware or drivers.
    Brigadier General:
  • 3,614 Answers
Nope. There's a problem on your videocard display.
Posted on Feb 28, 2008
  • micromaster
    micromaster Feb 28, 2008
    You've upgraded the monitor or the video card, and it's incompatible with the rest of your system.
    If you're working with an old monitor and new video card, or vice versa, it's possible that the two are incompatible. A new video card, for example, cannot bring an ancient monitor up to the video card's standard. If you suspect this is the case, contact both the PC/video card manufacturer (it's almost a sure bet these days that your PC came with a video card installed) and the monitor manufacturer and ask about compatibility. It is also possible that you have the proper hardware but not the right driver. A device driver is the program that lets the computer communicate with the hardware peripheral. If you're connecting a new monitor, make sure you've installed the proper driver for your monitor. First, you'll want to check the monitor manufacturer's Web site or read the product literature.
My dell laptop has horizontal lines across the screen
Last one I had with this it was the connection from the compute base to the monitor. difficult to chk and hard to fix yr self. hv it tested. cheers
Aug 04, 2012 | Dell Latitude D520 Notebook
I have this problem about my monitor, every time i open my computer a horizontal lines appear on my screen, my monitor is BenQ a flat screen ... can anyone tell me what happen and how to fix it ...thanks...
Could be multiple different issues here.
1) Your video card is getting old or if you recently replaced it may not work with your current PC.
2) Degauss your monitor using the settings directly on the monitor.
3) Download the latest drivers for your video card and mess around with the display resolutions as the card may not support your current resolution.
4) Your monitor itself may be the culprit and you need to send it in for repair.
If your still having issues, provide me a few more details about the problem and I may be able to further assist you.
May 25, 2011 | Intel Computers & Internet
My screen appears with a white stripe approximately 3cm wide which blanks out all the info - what is the problem? Please help
Welcome to Fixya.
This issue can be either the monitor is going bad or the video card is going bad. If you can get your hands on a spare monitor, try swapping it out and see if the lines are still there. If they are, then the problem is with the video card. You'll want to replace the video card if that is the case.
Otherwise, the monitor needs to be serviced for repair in order to correct the problem. Please understand that there are no applicable 'DIY' troubleshooting/fix for such problems - and only certified/trained technicians can get this rectified.
Thanks for using Fixya.
Apr 26, 2011 | Apple Computers & Internet
Hi my monitor has colored horizontal lines all over the screen i have tried checking all the connections .....no change plus the lines are still there when the computer is not connected to...
This is bad news, the problem is the screen panel itself, replacing the display would exceed the price of a new monitor. It is far cheaper to buy new, than to try and fix a unit that will cost an arm and a leg.
Jan 23, 2011 | Dell E228WFP LCD Monitor
Wide, snowy horizontal bars scrolling on Viewsonic VA1912WB
Changing computers doesn't help. Followed all suggestions from Viewsonic Tech Support. Problem is in monitor circuits--had to replace it.
Dec 23, 2009 | Acer AL1916W 19" LCD Monitor
A horizontal (2mm wide gray line) appears along my screen steady.
try plugging into an external monitor.. if the screen looks ok then it is most likely the laptop LCD screen is bad.. had the same thing on a HP laptop .. replaced the screen and all was well again with the world...
Dec 23, 2008 | Computers & Internet
Horizontal lines
i suggest you change video board .
Apr 19, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
Monitor problem
Your screen resolution is not right. As you cant see to do anything you can boot into safe mode or vga mode and change your screen resolution to suit the monitor. I am assuming that the barcode bit is the windows but very scrunched up. If this display is additional and on top of a normal windows display you have a hardware problem
Feb 28, 2008 | Computers & Internet
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
